Block Heater Working?
/ Block Heater Working? #1
MYOLFarm
none yet
Got a ck3510 se, I've questioned my block heater before but tractor always starts, it was below zero this weekend, had it plugged in but tractor would not start, I can put my hand on the block heater and it is stone cold as well as all surrounding areas of the block so I have to assume it is NOT working, anybody else see this ? Thank you.
/ Block Heater Working? #3
Check the cord. They do deteriorate at the engine block.
A tarp and small 1500 watt heater will work well in an emergency.
/ Block Heater Working? #4
How long had it been plugged in?
/ Block Heater Working? #5
You can put an ohm meter across the terminals to read the resistance. A 400w 120v block heater should read about 36 ohms.
OK, thanks, was going to try this but had no ohm # to ref
great idea, thanks
/ Block Heater Working? #10
Overnight
I normally can feel some heat having it plugged in for 2 hours so overnight should definitely make it warm to the touch. Make sure your extension cord has power to the end of it. Also, a common failure point is the connection of the heater cord to the element...check that.
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
Frontier Forks (A64911)
Frontier Forks...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
2013 WINSTON AP22024-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
2009 POLAR TANK TRAILER (A67714)
2009 POLAR TANK...
2012 DIAMOND T TRAILER GOOSENECK TRAILER (A67714)
2012 DIAMOND T...
