Long shot and sorry for off topic need help with f250 manual locking hub
   / Long shot and sorry for off topic need help with f250 manual locking hub
Well no surprise I post f250 question on a tractor forum and get more responses than if I had posted on Ford forum. thanks all!! Pic of new locking hub. Circled what broke on old which left gears in hub on axle. I PB Blasted then drove around. The locking gear popped out a bit and unlocked. I could grab with needle nose pliers and then was able to pull it out. I then was able to grab the plastic tabs and pull remaining gear set out. Of new doesn’t fit and need to order another. Thanks again!!
Weird can’t attach a photo from phone
   / Long shot and sorry for off topic need help with f250 manual locking hub #14
Sounds like a good ending!!!! What year truck is this?
2016, 56k miles. Honestly a bit disappointed that they needed to be replaced so soon. The truck gets light, regular use. I guess either my expectations are too high or is true that some things aren’t built like they used to be. Also interesting how much plastic, maybe a must have?
Thanks again?
Joel
   / Long shot and sorry for off topic need help with f250 manual locking hub #16
The spin out I showed is '00 with 280K miles. Won't auto engage anymore. Both are original. Moderate use.
Your entire wheel hub assembly is different.
Glad you were able to get it apart. Hope the replacement serves you well!!!
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A55851)
Generac Yanmar...
2007 Sterling Acterra Dump Truck (A51691)
2007 Sterling...
John Deere Gator (A53317)
John Deere Gator...
2013 Ram 1500 Crew Cab Pickup Truck (A55852)
2013 Ram 1500 Crew...
2017 DRAGON 150 BARREL TRAILER (A55745)
2017 DRAGON 150...
