   / Share Pics of People Hauling or Towing Something Wrong #17,761
Add in there Fab Rats, Robby Layton Nation, Chad's Fab, and BSF recovery Team, all friends of above. Fab Rats is Merlin's cousin. Robby paints some of there vehicles. Chad does the electrical for them. Jon
   / Share Pics of People Hauling or Towing Something Wrong #17,762
I watched a couple of Fab Rat and Robbie's episodes, including the complete "Golden Nugget" restoration. They get a little too far off topic though.
   / Share Pics of People Hauling or Towing Something Wrong #17,763
This would prevent those frames from bending back over because it solves the vertical weight distribution, but it doesnt solve the horizontal weight distribution, so it is likely to oversteer.
Why do people keep inventing such ******** ??
Yeah that works just like a tag axle, and it only works for a load in the bed.
Here is the "original" patented design that works with trailers:
Much more stable in both vertical and horizontal weight distribution.
   / Share Pics of People Hauling or Towing Something Wrong #17,764
Truck frames crack from lateral forces too... just look at the rubber the trucks rear wheels lay down in corners... it needs a 4wd truck to pull it around the corner, because the rear wheels dont deliver much traction when they skid sideways...
I'll stick to a hay wagon type trailer... If you cant back that up, you shouldnt be hauling the loads such trailer can load, anyway....
   / Share Pics of People Hauling or Towing Something Wrong #17,765
Fair enough, unless you've been using regular trailers for years with a single pivot point hay wagons have multiple pivot points and isn't it almost the exact opposite of how you back a regular trailer up? One of these days when I get the time I'm sure I'll confidently master it or close to and I only have a 4x8 2k wagon lol.
   / Share Pics of People Hauling or Towing Something Wrong #17,766
Coming home tonight I seen a Subaru outback driving slowly with hazards on coming towards me. When he was even with me I seen he had the front wheels of an atv on the rear bump with the back wheels on the ground as a trailer. Trailer and machine all in 1
I had to chuckle and glad I wasn't behind him
   / Share Pics of People Hauling or Towing Something Wrong #17,767
Outbacks are very versatile! :)
I'm right at, but not over, each spec - tires, axle, hitch, tow rating. (But this was a slow cautious 15 miles home on empty back roads).
p1730707rym186d2onhwy-jpg.368644
   / Share Pics of People Hauling or Towing Something Wrong #17,770
Short trailers are a b*tch to back up. 6 to 8 meter (20 to 26ft) hay wagons are most regular, which are easier because only the triangle will jackknife and not the trailer itself.
   / Share Pics of People Hauling or Towing Something Wrong #17,771
Short trailers are a b*tch to back up. 6 to 8 meter (20 to 26ft) hay wagons are most regular, which are easier.
Fortunately it's small and light enough to use the (manual method) if I get in a bind and not grossly overloaded lol slowly but surely I'm getting a little better at it using old beat up garden tractors anyway. And can do it pretty competently if I push it with an ATV.
   / Share Pics of People Hauling or Towing Something Wrong #17,772
I drove a Ford 9000 flatbed with a 24' flat bed wagon behind it. With practice I could back it over uneven ground in a straight line or around a slight corner. I have heard of people (never seen it) who could back a set of doubles. One won a bet from a former boss when he said he could back his set around the small restaurant at truck stop. He was allowed one or two pull-ups but had to back it from where it was parked back to where it was parked. My boss said he had bet $200 and lost but it was worth it to see the man's skill.
   / Share Pics of People Hauling or Towing Something Wrong #17,777
No bridge? Get on the boats.
Bruce
   / Share Pics of People Hauling or Towing Something Wrong #17,780
Got to give the '+1' for Subaru. 🤣
Never appealed much to me, but for sure they've got to have one of if not the highest owner loyalty rates.
No experience with long trailers, but +1 on short ones. I've got 2...a 4x8 and a 5x10. The 5x10 backs pretty well, but forget about the 4x8. It goes wherever it wants, though it's a lot more controllable using the tractor vs a truck.
2017 Dodge Charger Sedan (A59231)
2017 Dodge Charger...
3-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
3-Gang Reel Mower...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
ALLISON TRANSMISSION (A55745)
ALLISON...
