Hydraulic Top link on RK 37,, what works?
   / Hydraulic Top link on RK 37,, what works? #1
Skipper T
Member
Central IL
RK 37HC
Wanting to see what top links folks have used and what the outcome has been.
I would like to add this to my RK 37 but looking for information.
Thanks
   / Hydraulic Top link on RK 37,, what works? #2
Ten years ago I purchased a Fit Rite hydraulic top link. It's a category two unit and has performed flawlessly.
   / Hydraulic Top link on RK 37,, what works? #3
Thanks
Look at this link. Get the asked for dimension and look for a top link that is close to that dimension when half way extended.
Good luck. :)
   / Hydraulic Top link on RK 37,, what works? #5
TractoTYMe, Thanks for the information. After reviewing this top link and doing a bit of research,, I have ordered this unit and it is enroute as we speak.
I will send out an update once received and installed.
   / Hydraulic Top link on RK 37,, what works? #9
Skipper T, did you ever get the top link installed and if so how does it work for you?
2007 GALYEAN 130BBL VAC TRAILER (A58214)
2007 GALYEAN...
Tool King 12-Ton Hydraulic Pipe Bender (A59076)
Tool King 12-Ton...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2014 Ford F-150...
SHOP FAN WELDING CART (3) JACK STANDS (A54757)
SHOP FAN WELDING...
2019 Haulotte Star 20 ACE 19ft Scissor Lift (A55973)
2019 Haulotte Star...
CRAFTSMAN PUSH MOWER (A58374)
CRAFTSMAN PUSH...
