Pressure relief valve PSI setting
/ Pressure relief valve PSI setting #1
kmatney
Yanmar 226D
I have added a hydraulic top link to my compact tractor. What PSI pressure should I adjust the pressure relief valve to on the directional control valve? The hydraulic pump system pressure is 2216 PSI and the flow rate 6.6 GPM. The hydraulic directional control valve is an open center with 1 spool, the max GPM is 10, and the pressure relief is adjustable from 1500 to 3600 PSI. The top link is a double acting cylinder with a double piloted check valve.
/ Pressure relief valve PSI setting #2
Welcome to this forum
Why do you think you need to adjust pressure relief valve due to utilizing hyd center link? Is directional control valve also new? IMHO pressure relief should be set close to tractor hyd pressure which you stated is 2216 psi
Thanks for responding. You are correct, the control valve is new. Significant information I failed to include in the original post.
/ Pressure relief valve PSI setting #4
Is this new valve mounted before or after the original existing relief valve? If before it must be set to match original pressure requirement of the system. If after it can be set to the pressure you want the center link to operate at since original will still be master and limit the max pressure.
Thanks for responding. This valve is mounted before the existing relief valve.
EZ Trail 3400 Seed Tender Wagon (A64047)
EZ Trail 3400 Seed...
208316 (A58375)
208316 (A58375)
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
TOOL BOX (A63569)
TOOL BOX (A63569)
