Good morning!!!!
   / Good morning!!!! #164,793
Pole saw for Mom's trees came in today, looks and feels good. too bad the next few days high winds and rain are predicted.
The pole reaches to the street light, 25'
View attachment 783857View attachment 783858
70 people at the whole food plant based meeting today, we are really growing. We made the cover of the local magazine and a lot of the people who saw the article came out for heart month.
Where do you plug the battery in? :)
   / Good morning!!!! #164,794
I can see the image I uploaded both in Safari on the desktop and in the TBN app on my phone - which is version 7.1.12 (21000005)
I can’t find a TBN app (for an iPhone or iPad) in the App Store, what is it called? I use Tapatalk which might be my problem.
   / Good morning!!!! #164,795
Check, What are the attachments that the canoe is resting on? Considering hauling a kayak but have a (4 door) short bed also. Ok on the highway ?
Looks like basic foam gunwale blocks and ratchet straps through thendoor openings…
   / Good morning!!!! #164,796
Fritz, you can try and test the thermocouple. Usually they are the troublemakers. Not too expensive to replace.
After years of standard WHs, we went with a condensing tankless propane WH. It's 199K BTU, 98% efficiency. The venting is PVC pipe. We will never go back to a tank WH. It's really nice to never run out of hot water....
The hot water heater came back to life and water is hot again. The pilot is lit and look normal. Guess it could be an intermittent problem with the thermocouple. Will monitor to see if it was a fluke.
   / Good morning!!!! #164,800
66F and sunny with lots of wind @ 17:00, high temp today in Akron was 71F which was a record.
Glue up done on blank for handles, bottom for the portable downdraft sanding table trimmed and glued into the sides:
Missed the alignment on one end by about 1/16th, either the glue was starting to set up or the plywood was just so warped it didn't want to move in the groove. The dados on the top aren't quite wide enough to accomodate the full 2 x 4 sheet of pegboard either ... but I can probably fix that later. Close enough for what it is though.
Some additional clean up and organizing done out there, plus air nailers and crown stapler hauled up from the basement.
Also hauled down a bunch of stuff from upstairs to the basement.
Woman fixed the leftover sausage patties, a couple of eggs and toast for lunch. Hit the spot ... (y)
Starting to run out of steam, going to head out and refill the feeders, then probably grab a shower and call it a day.
(4) ALUMINUM RIMS FOR KAWASAKI MULE (A58374)
(4) ALUMINUM RIMS...
Vivohome Single Stage Vacuum Pump, Model VB150, 1/3 HP, 110 Volt, Vivohome Gage Set (A59076)
Vivohome Single...
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
500BBL WHEELED...
SHOPBUILT T/A TRAILER (A52708)
SHOPBUILT T/A...
CLARK FORKLIFT MAST W/ 3PT HITCH (A58374)
CLARK FORKLIFT...
