What size earth auger bit do you use for a 4x4 fence post?
   / What size earth auger bit do you use for a 4x4 fence post? #1
Metro Atlanta
I do not have a tractor yet.
I've seen 3x the size online but nobody seems to do that in real life. What size bit would you use for a 4x4 post? I will use either concrete or the foam stuff, probably the foam, so maybe the hole should be smaller diameter?
   / What size earth auger bit do you use for a 4x4 fence post? #2
Learning2Tractor,
Diagonal on 4x4" post is 5.65" so add a min of 1 inch to each side of diagonal for 7.65". Bore a minimium hole size of 8". Augers come in 8" & 10"
Never heard of foam. What is foam?
   / What size earth auger bit do you use for a 4x4 fence post? #3
depends on how deep you want the hole AND how good you are at making the hole straight.
regularly I use a 8" bit for a 5-6" fence post (rnd) set 4' in depth and I know with my PHD i creep the hst a little forward half way through digging the hole so it stays vertical. No problems with hole size. Creeping to keep vertical creates an oblong hole.
last summer i set 24' long laminated posts that were 7 1/2" x 7 1/2" (5 laminated 2*8's) 7 1/2 feet in depth and borrowed a neighbours 12" auger and this worked fine. Also had to creep forward a significant amount to keep hole vertical.
   / What size earth auger bit do you use for a 4x4 fence post? #4
Learning2Tractor,
Diagonal on 4x4" post if 5.65" so add a min of 1 inch to each side of diagonal for 7.65". Bore a minimium hole size of 8". Augers come in 8" & 10"
expanding foam
   / What size earth auger bit do you use for a 4x4 fence post? #5
Yeah, polyurethane foam. Thats what I thought but I wanted to see what Learning2tractor responded with. That crap don't last since polyurethane breaks don't with moisture and UV and becomes brittle in about 2 years. Then someone taps your fence post and it falls over.
I'm a compacted soil or mixed concrete into the hole kind of guy. If I'm going to do the work, I will do it once NOT many times.
Amended response. When using wood post. I coat pressure and non pressure treated wood with "roofing cement" for the entire length that the wood will be exposed to earth plus extra 3ish inches above ground level. Posts don't rot off at ground level because water and bacteria can't get at the wood to rot it.
   / What size earth auger bit do you use for a 4x4 fence post? #6
I use a 9" auger to put in standard split rail line posts (6"x3") and corner / end posts (4"x4"). For non tensioned fence types I only pack the soil, and don't use concrete. I would not use a foam product on a permanent fence of any type.
   / What size earth auger bit do you use for a 4x4 fence post? #7
For the past five years local utility is using foam when setting poles. They are not having poles fall over
   / What size earth auger bit do you use for a 4x4 fence post? #8
Streetcar,
Several huge differences in what the power company is probably using for urethane foam and what guys walking into the local hardware are going to be able to purchase. I spent 20+ years in advanced elastomers and there are many grades of urethane for many different applications. I could bore ( pun intended ) your with the details but finished cured urethane can range from glass like to foamy elastic stretchy sponge just by changing the polymerization components/ ratios.
Power company is also sinking that power pole a min of 10 feet and probably closer to 15-18 feet into the ground and they are probably using a very small overbore tolerance which all produces a tight fit and very little foam gets used.
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
2020 John Deere 325G (A55272)
2020 John Deere...
Portable T/A Vertical Cement Silo (A56857)
Portable T/A...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
