NTM. Ford 2000.
/ NTM. Ford 2000. #1
careyo63
Elite Member
77 Yanmar YM2000 63 Ford 2000
Had to remove a lot of paint. Found the Ser.#'s I believe. L. side Trans Housing. By the Starter 1201 ? Then below it 31038? On the Eng. block L.side CONN 60150. Clutch is stuck and with a FEL. front mount Hyd. pump it's going to the shop this Wk.. Major Fbomb. Man had it for months and no mention of it. Shifter problems is what was told to me. My search which I only had it a few days. I come up with 1963 ? 4cyl. gas. 4Spd. Rev.. Best place for manuals would be nice info. for it Both Owner Parts/repair if need be. Loaders working and seems to be running good. 12V. also. There is a Rev. problem. Have to turn it off to get it to lock in ? That's wierd to me of course. I'm thinking Shifter problem ?. Any Info or IMHO would very Appreciated.
Carey.
/ NTM. Ford 2000. #2
You can download a free owner's manual for it here: https://www.ntractorclub.com/manuals/tractors/Ford 4000 Owners Manual.pdf
Here's how to decode the model#:
First number (1 digit)
2**** - 134 ci gasoline or 144 ci diesel engine
4**** - 172 ci gas, LP-gas or 172 ci diesel engine
Second number (1 digit)
*0*** - Industrial models produced prior to 1963
*1*** - Industrial and agricultural models produced after 1963
Third number (2 digits)
**10 * - Row crop
**11 * - Offset
**20 * - Utility-type w/adjustable front axle
**21 * - Orchard type w/ non-adjustable front axle
**30 * - Utility-type tractor w/non-adjustable front axle (light industrial)
**31 * - Low center of gravity (LCG tractor)
**40 * - Heavy duty industrial tractor w/sub frame
**41 * - Heavy duty industrial tractor w/sub frame & cast grille
Last number (1 digit)
*1**0 - Four-speed w/o PTO
*0**1 - Four-speed w/o PTO or hydraulics
*1**1 - Four-speed w/PTO
*0**2 - Four-speed w/hydraulics, w/o PTO
*1**2 - Five-speed w/live PTO
*0**3 - Four-speed w/hydraulics and PTO
*0**4 - Select-O-Speed w/o hydraulics or PTO
*1**4 - Select-O-Speed w/o PTO
*0**5 - Select-O-Speed w/hydraulics and single-speed (540 rpm) PTO
*0**6 - Select-O-Speed w/hydraulics, 540 and 1000 rpm PTO and ground-speed PTO
*1**6 - Select-O-Speed w/two-speed (540 and 1000 rpm) independent PTO
*1**7 - Select-O-Speed w/540 and 1000 rpm independent PTO and ground-speed PTO
*0**9 - Five-speed w/live PTO
Suffixes
-1 - Tricycle with single front wheel
-4 - High clearance with wide front
-L - LP gas engine
-D - Diesel engine
Thousand Series tractor serial numbers -
1962 Serial number 1001 - 11947
1963 Serial number 11948 - 38930
1964 Serial number 38931 - up
Part number identifiers cast into 134 and 172 engine blocks (lower right side)
EAE 6015 - 134 1953-1957
EAF 6015 - 172 1953-1957
310905 - 134 1958-1959
310609 - 172 1958-1959
B9NN-6015C - 134 late 1959 early 1960
B9NN-6015A - 144D late 1959 early 1960
B9NN6015J - 172 late 1959 early 1960
B9NN6015B - 172D late 1959 early 1960
C0NN-6015G - 134 sleeveless late 1962-1964
C0NN-6015H - 144D late 1960-1964
C0NN-6015C - 172D-G late 1960-1964
C0NN-6015J - 172 late 1960-1964
/ NTM. Ford 2000.
**10 * - Row crop
**11 * - Offset
Suffixes
-L - LP gas engine
-D - Diesel engine
This Info. is what I found to get the Yr. model. Thanks for the Manual Much better. I may have seen this one but it didn't have the 2000 label. Have some good reading to do now. :)
/ NTM. Ford 2000.
New Clutch, Pressure plate, Bearings and seals. Hard to shift into Rev. everything seems normal while in gear. All forward gears are fine. Was told I had to push hard to shift into Reverse. The shop guy had trouble. That worked a couple few times. After some use Maybe an Hr. by Time not Tach. Hrs. now "No Rev.." I gave up trying to get it in gear. I heard Rev. was the weak and it's sure looking that way. I'm guessing Shifter? any advice would be appriciated. Shifter repair I can most likely handle. Sent it out to a Tractor repair shop for the clutch replacement. Ended up big $ SMDH. Only one good arm and hand so a split by me wasn't happening. No PS. found out quick that's a must with a FEL.. Fuel problem getting to the Carb. come to find out also. I took a beating no doubt!... Thanks!!!
/ NTM. Ford 2000.
It's getting better! They're back in it last I heard Yesterday. So My guess, Had it since last Fri. 2 G. clutch and Alternator job from a 700.00$ Est.. True! 1300.00 plus now. How the Alt. Wires and gauges was replaced by them I have no idea!! Wow!! Looking at the Rec. which I paid to get it back. No I didn't tell them to do it! Only done a few hundred in my lifetime. No wonder the bill was so high. :rolleyes: Steady fuel drip out of the Tank. Have to cut it off. My guess they want to get a good high Amp. spark!! and fire that baby up!! Impossible to miss that! :rolleyes: You have to cut the fuel off or get a big puddle of gas. found that out in less than 2 days that I had it. Which is still true.
200.00$ For the FEL. 4/bolts to the Rear Axle. 50$ a bolt True!. I bet I get charged again.
Cleaning up the Yanmar now for grass season. Degreased and washing it. 15yrs. trouble free!! All Org. it looked like it just rolled off the boat from a rice patty field. 79 model. Biggest repair Alt. rebuilt 72$ 10Yrs. ago and a new battery. 975hrs. on the Tach. I put on it. I did reline the rear tires Yrs. ago. Gempler! Not the first complaint. It's Never let me down yet. Paid 2800.00$ in 08 for it from Yanmar/Fredricks supplied dealer. When the starter finally did quit I could still roll it off If I needed to. I was even in it before not long after I bought it cleaning it up and turned the brushes. The shop Mentioned it. Nothing left of them.:) 50$ a bolt two on each side. LOL.. bad part It's true. Im holding the Reciepts. Back on CL. is my bet. I don't think it will hit my property again. Told them just put back together forget it. How much am I going to owe them. Said He has add it all up. Serious 2 Grand total watch this..................... Here's the 4 50$ Bolts in the Pic. LOL!! I mean nuts and bolts. I'll let you know who not to use in Ga. that's for sure.................. Your see the Rec.!! All the replies. I wouldn't know what to say either!!!.............
