8n running a 6 foot hog
   / 8n running a 6 foot hog #11
8Ns are ok. A '53 Jubilee or '54 NAA are better due to their engines. A '55 and up are better still due to improved rear wheel seals that don't leak on the brakes and you can also find some with live power and power steering. Those are the holy grails of antique/vintage small Ford tractors.
sounds like you know your machines. not to distract from OP's thread, post some pics of your inventory, regards
   / 8n running a 6 foot hog #12
I've learned a lot in the last few years. Here are a few pics that I currently have:
   / 8n running a 6 foot hog #13
like the vintage 850, a hoss, OP: update progress
   / 8n running a 6 foot hog #14
We used to run a 6' rotary brush hog on our little Ford 8N all the time growing up in the 60's and 70's. It was the designated mow tractor for road ditches, end rows and other "junk" areas (brush and whatnot) around the farm. The "good" mowers (sickle bar) were used exclusively to cut hay. Never had any issues mowing with the old Ford, but we did have front weights and filled tires.
Horsepower is a rate. A speed.
In this case, like a snowblower, the horsepower required is a function of the pounds/minute (or tons/hour) rate of material processed.
The pounds/minute of grass a mower cuts (& hp required) is the product of:
- Vegetation density (pounds per square foot) x
- Mower speed (linear feet/min) x
- Mower width (linear foot) x
- Overlap percentage (%)
That’s four different load factors that will determine the horsepower required. For some reason we only talk about the width of the mower (or snowblower).
A mower is too wide when you can’t go slow enough, adjust your overlap %, or it’s too heavy for the tractor to safely handle
I thank you for all the well thought out input
Thanks for the well thought out advice
   / 8n running a 6 foot hog #18
rock solid, tires & sheet metal looking good. had a TO 35 for 28 yrs, but yours is a notch up the vintage ladder
   / 8n running a 6 foot hog #19
Everything is kept under cover and we generally are very respectful of our equipment. That 850 has thousands of hours on it and is 43 years old.
2016 PETERBILT PB337 FLATBED TRUCK (A57192)
2016 PETERBILT...
2020 PETERBILT 567 SLEEPER TRUCK (A56138)
2020 PETERBILT 567...
2017 BOMAG BW211 DH5 SMOOTH DRUM ROLLER (A52707)
2017 BOMAG BW211...
2019 Chevrolet Silverado 2500HD Crew Cab Liftmoore 2700AR 1 Ton Crane Service Truck (A55973)
2019 Chevrolet...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
1977 Ford F-100 Ext. Cab Pickup Truck (A53422)
1977 Ford F-100...
