4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 18,974
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
The only part allowing synchronization is the cross tube. Without that, the cylinders would move willy-nilly depending on the drag of the pins and cylinders. The power/pressure will take the path that's easier FIRST then balance if the weight is balanced. I'd like to see you lift something without the cross tube.![]()
The cross tube is really only there to hold the plates inline to make attaching it easier. It’s not nearly strong enough to truly synchronize the cylinders. It relies on the bucket to hold them aligned.
