Anybody ever see a 3pt attachment that did the following....
   / Anybody ever see a 3pt attachment that did the following....
Be careful on pin weight.
I have a Carbon 35 bumper pull toy hauler. 1,500lbs tongue weight with the toy in, 1,700 empty.
My L4060hstc will lift 1,700 on the loader barely, if you get the load very tight or under the SSQA. Lifting the tongue with my quick hitch & trailer mover creaks a lot.
The toy hauler pulls poorly & I should have gotten a 5th wheel. Most 5th wheels have 2-3k lbs of pin weight. An unloaded gooseneck is likely to weigh a fair bit less than a 5th wheel though.
Just be sure your machine can lift the appropriate weights. A quick hitch, teailer Moorer & 2" reciever move the weight back probably a foot or more. That drastically decreases your capacity.
Tractors are designed to tow from the drawbar not the 3pt. Especially with a gooseneck the hitch point is above the axle. If the trailer hangs, the tractor can easily drive out from under the hitch & roll. Towing with the 3pt isn't approved by the safety police. I have no problems shuffling trailers around the yard slowly with my 3pt. But wouldn't tow at any real speed, across rough ground or on a road unless I hitched to the drawbar. Just understand the risks & physics.
This is for my 4707. It'll be fine. Lift capacity is nearly 5,000lbs.
   / Anybody ever see a 3pt attachment that did the following.... #13
Please follow up with whatever you decide. With pics for "slow" guys like me. Thanks!!!!
Well, I bought the backing structure to a set of pallet forks (no forks though, as I have some spares) that is rated for 4,000lbs. We will use this as the starting point for my idea. I'll keep y'all updated as I go.
   / Anybody ever see a 3pt attachment that did the following.... #15
I brainstormed this idea several years ago and gave up.
My idea was to modify my QH to accept SSQA attachments. Couldn't figure out how to do that without losing the QH capability that I use a LOT. I made a hitch adapter that can go on 3pt and/or my QH. But I still don't have fork capability.
I've got a set of SSQA forks. But couldn't figure out how to adapt them to fit my QH without losing the SSQA ability. 🥴
I built a SSQA tree puller. Then added 3pt capability to it. But it also won't fit my QH.
Off topic but I have a similar homemade tree puller. It's a great tool. Handles 3-4" trees with a 45 hp Cat. 1 tractor. Lift and pull at the same time to double the force on the tree. I pull out the trees and carry them straight to the pile.
   / Anybody ever see a 3pt attachment that did the following.... #16
I've pulled hundreds of trees with mine. Great attachment.
OK, I finally finished it. I converted a SSQA backing structure for forks into a 3pt hitch setup. Also added a conventional hitch and a gooseneck hitch. Forks can be put on and taken off fairly easily. I imagine they'll be left off most of the time as I tow trailers around the farm more than any other task with this tractor. I also had to take a few inches out of the top of the backing structure in order to lower the gooseneck ball.
Here it is:
   / Anybody ever see a 3pt attachment that did the following.... #18
Very nice!!!!
To remove the forks you slide them to the center where the notch is cut out of the bottom guide?
The load on this tool is going to be on the vertical stem that the top link fastens to. Your tractor will apply a serious load on that part when lifting something toward the tips of the forks. If you think it'll handle the load, everything should be plenty strong!!!
Good work and thanks for the pics!!!!
You can't tell from the pictures, but the gooseneck tower goes all the way to the bottom. Also, the top rail is beefed up towards the tractor.
   / Anybody ever see a 3pt attachment that did the following.... #20
Yep, I studied the pics closely. How far down the tower goes isn't the issue. The issue is the leverage applied from the top rail of the fork mount upward to the top link bracket. It's really hard to laterally brace this. You can't brace forward with any effectiveness. You can't brace rearward with any effectiveness. So you are reliant on the tower itself.
I couldn't tell for sure but it appears you fabricated the tower? If so, the material used is critical. For example, I doubt 4" 1/4" wall square tubing would handle the load. But I don't know the lift capacity of your tractor at the pins?
There are some very intellectual members here. Maybe one of them will see this and chime in. If you share the construction materials used and a few measurements they'll tell you exactly how much force the tower will withstand. I'm no where near that smart. So I tend to overbuild.
2019 Ford F-550 ETI ETC37IH 37ft Insulated Bucket Truck (A56858)
2019 Ford F-550...
VERMEER R23A TWIN BASKET HAY RAKE (A58216)
VERMEER R23A TWIN...
2016 Toro Workman HDX-D Utility Cart (A55787)
2016 Toro Workman...
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
202479 (A54757)
202479 (A54757)
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
