Case IH 695 No Start
   / Case IH 695 No Start #1
Asar2525
Member
Pownal, VT
Farmall 140/Super C/International 300
Took the injectors out of my Case IH 695 (D239 German diesel) and ended up replacing two of them. One had the tip of the nozzle broken off and the other had a split nozzle nut, but the tractor was running. Took 3 weeks but the new injectors arrived, I installed the new injectors, I bled the system and the tractor will not start.
Thoughts? I bled by loosening high pressure lines and cranking until a good spray came out. Did I miss something here?
Thank you in advance.
   / Case IH 695 No Start #2
I would pull one of the new injectors and see if the pump is sending enough pressure to pop the injector.
Best,
ed
Hi Ed,
Do I need to have the fuel return line hooked up for this test? Thank you for the quick response.
   / Case IH 695 No Start #4
Hi Ed,
ideally yes, I believe you will get results without it though.
Best,
ed
I did get the tractor started. I let it sit overnight and bled the injector lines once more. It fired up after this.
   / Case IH 695 No Start #6
Thanks for letting us know:)
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2005 Mercedes-Benz C-Class Sedan (A50324)
2005 Mercedes-Benz...
Blue-Jet Liquid Fertilizer Applicator (A51039)
Blue-Jet Liquid...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
PORTA CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTA CABLE 150...
