   / Share Pics of People Hauling or Towing Something Wrong #17,601
It was a dumb idea to begin with. Poor communication from the sawyer.
   / Share Pics of People Hauling or Towing Something Wrong #17,603
A neighbor was having a 150' dead douglas fir cut down by a tree company. It was not near a house, they just did not want it falling the direction of the driveway. I authorized them to fall it my direction if I could have the firewood. The tree company climbed the tree to about 100' and attached a rope. They had a helper go to the place they wanted the tree to land and snug up the (long, probably 200') rope. I asked the feller if that helped much. He said 100 lb pull at 100 feet (which is 10,000 ft-lbs of torque) in the direction he wanted can't hurt. The tree fell with feet of his mark. Douglas firs are straight as an arrow, not like the tree in the video.
   / Share Pics of People Hauling or Towing Something Wrong #17,604
I wonder if one of those elastic tow straps to an anchor point, maybe tightened with a come-along, could help steer the tree even after it started to fall. Do tree services ever do this? Amateurs? (But not with a vehicle!)
   / Share Pics of People Hauling or Towing Something Wrong #17,605
Bull rope is not elastic. Elastic has too many stored energy issues to use in pulling a tree down.
   / Share Pics of People Hauling or Towing Something Wrong #17,606
Another thing I have been doing wrong! I have often "Pulled" (put tension on a line to initiate a fall in the desired direction) a tree using a come-along and line. Most of the line is dacron, but I usually include a length of nylon to take advantage of its elasticity. My rationale has been it is better to have (more of) the strain in the line than in the fibers of the tree.
   / Share Pics of People Hauling or Towing Something Wrong #17,607
In the mind of this amateur, the purpose of a line in the intended direction of fall is to get the center of gravity over the notch where the supporting (compression) fibers are missing so gravity does the work and the hinge does the guiding. Felling wedges have the same effect, except a line is more likely to prevent a "fall back" (180° from intended) because, if the CG is behind the hinge and the (now tension) fibers from the notch are missing, the line provides some tension. Once a line goes slack, it provides no control. I have used guys or "preventers" rigged at 90° to the intended direction of fall to guide the fall away from an undesired direction.
A very instructive experience was felling my first large dead tree close to a building. I had used a line, notched and backcut without inspecting the notch. Later inspection revealed the heartwood was rotten and the remainder of the hinge was unsound. The hinge failed, tree spun on the stump, and fell 45° from the intended direction. I do not know if the line or Divine Providence "steered" the tree.
   / Share Pics of People Hauling or Towing Something Wrong #17,608
Doing about 75 mph…..nobody wanted to be behind him. One little strap holding it on, with the metal bed frame piece sticking up
   / Share Pics of People Hauling or Towing Something Wrong #17,609
What could possibly go wrong? Why do bad things always happen to good people? LOL
   / Share Pics of People Hauling or Towing Something Wrong #17,610
We are vacationing in Arizona and travelled from Illinois, it was in either New Mexico or Arizona we saw an almost identical car with a mattress on it like the picture above.
2018 Ford F-150 Pickup Truck (A56858)
2018 Ford F-150...
2013 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP TRAILER (A58214)
2013 TRAVIS BODY &...
2018 Nissan Sentra Sedan (A56859)
2018 Nissan Sentra...
Man Cave Metal Sign (A57454)
Man Cave Metal...
2018 Honda Odyssey Van (A56859)
2018 Honda Odyssey...
2007 Freightliner (A57148)
2007 Freightliner...
