I see Deere is following the others with a DOC
   / I see Deere is following the others with a DOC #1
CloverKnollFarms
Super Member
Indiana
TYM4820H
Just saw they followed the “bargain brands“ and now have a no DPF engine in the 5 series tractor. I’ve read folks say, if it worked so well, why aren’t the big brands using it? Well, now they are.
Sort if interested in seeing the 5050E
   / I see Deere is following the others with a DOC #2
Wonder if its a Mahindra diesel? Or Deere stealthily copied it?
Simpson has been doing the same for Massey in the 2600 tractors.
Seems it’s catching on.
   / I see Deere is following the others with a DOC #4
I had heard some rumors a while back it might be Fiat so FPT?
   / I see Deere is following the others with a DOC #5
No, it is a Deere engine, the 3029. They just changed from no EGR and a combination DOC/DPF to EGR and a DPF-less DOC for MY2023. Deere did actually use a few of the 3.4 FPT engines in the 5G specialty tractors, but those were the only FPT-engined Deeres out there. As far as I can tell, Deere stopped using the FPT engines in the 5G series in favor of their own 3029 and 4045 engines for MY2023.
CNH and AGCO use DPF-less DOC setups so it was them vs. Deere and [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] who used a DPF for under-75 HP utility tractors, until this year when Deere joined the no-DPF camp.
   / I see Deere is following the others with a DOC #6
Deutz engines are the same up to about 80 Hp. Wherever they are used, whether in their own tractors or TYM. There might be others too.
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
Informational Lot - Financing (A56435)
Informational Lot...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2017 Ford F550 Altec Bucket Truck (A52377)
2017 Ford F550...
