Filter wrenches.
/ Filter wrenches. #1
Krazi
Kioti CS 2220
CS 2220 coming up on my 50 hr service. Looking for ideas on filter wrenches. The oil filter looks to be in a tight place. Didn't look like my car filter wrench would work. HST filters don't look as problematic
/ Filter wrenches. #3
I use this style (one i have is a little different).
I can set it in place (grip the filter) in tight spots with my fingers, and then put the socket wrench in to loosen it.
/ Filter wrenches. #4
For the first oil change the filters may be painted along with the tractor. You may need to cut around the edge with a sharp knife so the paint isn't holding the filter. To remove filters I just use a plumbing type strap wrench. Mine is by Rigid but the Harbor Freight ones will do the job. Lowe's, Ace, and Home Depot are all options as is any auto parts store. Amazon has quite an assortment, too.
Amazon.com : strap wrench
/ Filter wrenches. #5
I have used this one: Filter Wrench
I have used every strap wrench, every object calling themselves a filter wrench, and even a homemade wrench called a screwdriver-through-filter wrench. But those channel lock style wrenches work the absolute best!
/ Filter wrenches. #6
I forget how many filter wrenches/sockets I have now. They pliers work the best when there is room. My chain wrench will get hold and not slip but you need room to work. The different sockets are nice when access is restricted. I should have something for almost every case at this point, knock on wood.
/ Filter wrenches. #7
When I had [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] L2800 it was bugger to getting filter of for the first time...pipe wrench work the best. (y)
/ Filter wrenches. #8
I am sold on this type of strap wrench. It has worked on every filter that I have attacked. With the assistance of a cheater pipe or 1/2" drive ratchet, it has removed even those that the strap crushed, which helped break the seal of the filter. Good luck
/ Filter wrenches.
A couple of these I have never seen
/ Filter wrenches. #10
/ Filter wrenches. #11
This is what I ended up getting to work.
I tried a strap wrench and big socket style and neither worked to break it loose. My biggest issue was breaking torque and the Channel lock wrench has 15 inches of leverage. Plus made in the USA.
/ Filter wrenches. #12
I have a collection of filter wrenches also. My go-to's are a regular steel strap wrench, and a chain wrench.
Since this is the op's 50h service, it bears repeating what @Roadworthy recommends in running a knife around the filter base if it's painted over. That thin layer of paint can really create difficulties. If the filters were not painted on, then they are almost certainly installed by the company gorilla at the factory.
One additional method not mentioned (applies more to the hydraulic filters) is getting a punch or chisel on the slotted base and tapping the filter loose. Air hammers work great if there is enough room.
/ Filter wrenches. #17
I am sold on this type of strap wrench. It has worked on every filter that I have attacked. With the assistance of a cheater pipe or 1/2" drive ratchet, it has removed even those that the strap crushed, which helped break the seal of the filter. Good luckView attachment 778679
i agree on this style. I carry 2 on my service truck for generators. Work every time.
/ Filter wrenches. #19
The biggest Burly guy that worked at the factory probably put it on with both hands and a breaker bar so whatever you get make sure it's something sturdy
/ Filter wrenches. #20
I DIY'd a similar setup for my Mitsubishi K3 engine.
It is so tight in the filter area that nothing slips in there.
I use a length of seat belt and vice grips.
Wrap the belt and grip with vice grips and presto.
(2) John Deere Row Markers (A64127)
(2) John Deere Row...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
Skid steer Asphalt attachment (A61567)
Skid steer Asphalt...
2010 CHEVROLET SILVERADO 2500HD (A65643)
2010 CHEVROLET...
FLAT BED (A65643)
FLAT BED (A65643)
Location Info Please
