Tc35/40 cold oil pressure issue
   / Tc35/40 cold oil pressure issue #1
nyone
Elite Member
Ford 851
My fairly new to me tc40 will have low oil pressure when starting in cold (30*f). Yet in the summer and when the oil is warm it dosnt. At first the oil pressure light was staying on for 5-10sec when cold. I confirmed this with a mechanical gauge. At 30*f it takes about 15sec to get to 10psi. Then 30 sec to get to 30-35psi. When shut off it drops off very slow so I dont believe theres an internal leak.
First I'm going to change the oil/filter. It is very clean and has about 75hrs on it I believe. Is there anything I should be checking?
   / Tc35/40 cold oil pressure issue #2
Change your oil viscosity.
Also when you confirmed it with a mechanical gauge how long and what diameter was the sensing line.
Also pressure should drop quickly when an engine is shutdown.
   / Tc35/40 cold oil pressure issue #3
I'm with Lou. See what acceptable oil viscosities for your tractor. If you're running 15W-40 and 5W-40 is an acceptable substitute try that. It starts out at the thinner viscosity but as the tractor warms the oil becomes 40.
   / Tc35/40 cold oil pressure issue #4
I will go with oil viscosity as other gents mentioned. if you live in a very Cold area then an insertion type oil sump heater may not be a bad idea.
   / Tc35/40 cold oil pressure issue #5
My TC40DA, bought used in 2008, does the same thing. I use NH SAE 10W-30, which is what came in it from the factory. My manual shows SAE 10W-30 is good for -10 to 120 F. SAE 5W-30 is good for -20 to 60 F.
I had a 1/8in pipe hose on the gauge. I tapped the gauge in off the front of the head.
I was suspecting oil viscosity also. This engine dosnt get dirty oil even after 60hrs I can see through the oil on the dip stick.
I think for this type of issue putting a sump heater on it would be more of a crutch than a repair. The machine starts great even if its 6*f so want to keep this as cold ready as I can with no 120v inputs as it may be at an offgrid property doing snow removal of a 1/4mi long road.
   / Tc35/40 cold oil pressure issue #8
My choice of oil year round is Rotela T6 5w-40 or Amsoil diesel 5w-40.
Those are the oils that I put in everything except the old Dyna-hoe with the 4-53 Detroit.
   / Tc35/40 cold oil pressure issue #9
Could not disagree. I think you might see a difference hopefully after oil and filter change.
T6 5w40 is also my main oil. I even ran it in my 09 accord for about a year when I had oil burning issues, it fixed them.
I havent put enough hours on this machine to change the oil yet but will be doing that very soon.
International 424 Loader Tractor (A59814)
International 424...
2013 Nissan V8 Titan (A57148)
2013 Nissan V8...
2023 Chevrolet Tahoe SUV (A56859)
2023 Chevrolet...
5'x8' Rubber Mats (A55272)
5'x8' Rubber Mats...
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
Giyi Tree Sheer (A57149)
Giyi Tree Sheer...
