Remove brush guard bolts-Kioti ck2610 (actually bobcat 2025)?
   / Remove brush guard bolts-Kioti ck2610 (actually bobcat 2025)? #1
wisconsitom
Bobcat ct2025 HST
Hey all, wanting to weld some expanded metal to my brush guard. 4 bolts hold unit to tractor frame. These bolts are not secured by nuts, but simply deadend in the frame...and they are tight! I mean putting all I dare on my good 1/2" socket, can't move em. I'm laying ony back underneath with great leverage and I think I might break some ribs if one of those bolts would start to spin!
Any ideas what a guy's got to do to get these 4 bolts out?
   / Remove brush guard bolts-Kioti ck2610 (actually bobcat 2025)? #2
Can you rent an impact wrench? Or a Good excuse to buy one if that’s an option. As I get older I’ve found that I grab mine more than before….😉
   / Remove brush guard bolts-Kioti ck2610 (actually bobcat 2025)? #4
Prolly damage the paint with heat…🤷
   / Remove brush guard bolts-Kioti ck2610 (actually bobcat 2025)? #6
Before I'd get into ruining paint, an impact or a breaker with a long cheater I could step on away from the FEL. The smoke wrench is last resort but does get plenty of use around here.
   / Remove brush guard bolts-Kioti ck2610 (actually bobcat 2025)? #7
I used my Dewalt bat operated impact wrench and an impact socket, worked quite well.
   / Remove brush guard bolts-Kioti ck2610 (actually bobcat 2025)? #8
Make sure to use a 6 point socket on this. Gives you more surface contact.
Thanks all. When I get back up there, will start with battery power impacts.....go from there.
Yeah, still nice paint where bolts attach-wouldn't mind not sizzling that off if I don't have to.
   / Remove brush guard bolts-Kioti ck2610 (actually bobcat 2025)? #10
2017 FOREST RIVER 20 T/A CARGO TRAILER (A53843)
2017 FOREST RIVER...
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
202480 (A54757)
202480 (A54757)
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A55852)
2014 Peterbilt 384...
CATERPILLAR 22" PIN ON BUCKET (A52707)
CATERPILLAR 22"...
2015 Chevrolet 1500 Silverado Pickup Truck (A55852)
2015 Chevrolet...
