Kioti Dk35 2013 no start (good battery)
   / Kioti Dk35 2013 no start (good battery) #11
it seems that you know a lot of things about kioti.
I have a similar problem.
The tractor wont start. It has good battery, the starter is working properly (have tried starting it with shorting + terminals , and its starts flawlessly.)
But with the key it wont start. I have tied a new keylock and there is no change.
I have seen that under the dashboard there are 4 relays. And I can not figure it out what each of them does. I figured that second relay from left starts the tractor. Try to replace it, but no change.
Can you help me?
Regards
   / Kioti Dk35 2013 no start (good battery) #13
Trace wires or go buy a remote starter switch..
Hook 1 end up to the battery and 1 to the small post/spade on the starter.. and press the button.. vroom..
U can even leave it hooked up till u find your answer/problem.. a couple of zip ties and your in business.
   / Kioti Dk35 2013 no start (good battery) #14
Hi thanks for reply, I would buy a remote starter switch, but I am worried, that if there is step by step to check all the things before starting. And if I bypass this it would eventually break.
Am I wrong ?
   / Kioti Dk35 2013 no start (good battery) #15
U have the step x step k0us was kind enough to print out..
Ur gonna have to get a manual
   / Kioti Dk35 2013 no start (good battery) #16
Am I wrong ?
Have you contacted your dealer? If you’re not comfortable doing some of the work suggested yourself, that’s what you should do…
   / Kioti Dk35 2013 no start (good battery) #17
Thank you very much for reply
I have contacted my dealer, but it seems that he does not care, tractor is not under warranty anymore.
I will try changing relays and measuring voltage. It seems very minor thing but cant figure it out.
   / Kioti Dk35 2013 no start (good battery) #18
Yep, changing the relays is a good idea. Take pictures before and after each switch out, just to keep track of what you did each time. Do one at a time is my suggestion….😉
   / Kioti Dk35 2013 no start (good battery) #19
Jarvis775, welcome to TBN! While you're at it, you might want to have a look at this post a few years back on a mystery starting problem with my NX4510HC. Your DK series might be similarly set up.
Tip for NX-Series Owners: Mysterious starting problem solved
The post will at least step you through some troubleshooting. Eventually turned out to be simply a chafed wire in a rear brake light housing that blew the fuse in the parking brake interlock circuit. Simple fix in that case. Good luck!
   / Kioti Dk35 2013 no start (good battery) #20
Thanks everyone for all the answers.
It was a relay. And the one marked as engine start relay (preety obious now 🤦‍♂️)
The problem was that it was a 5 pole relay (with NC and NO contacts) and I was testing it with 4 pole (NO).
Now it runs like a charm :D
Thanks again everyone.
2004 Ford F-250 4x4 Crew Cab Mechanic Service Truck (A49461)
2004 Ford F-250...
2009 Chrysler 300 Sedan (A48082)
2009 Chrysler 300...
2022 GMC Acadia SUV (A48082)
2022 GMC Acadia...
2018 HINO 268 26FT BOX TRUCK (A50505)
2018 HINO 268 26FT...
2016 FREIGHTLINER M2 26FT BOX TRUCK (A50505)
2016 FREIGHTLINER...
2013 MACK CXU613 SLEEPER (A50505)
2013 MACK CXU613...
