K5lwq
Elite Member
- Joined
- Aug 6, 2017
- Messages
- 4,920
- Location
- Mineola, TX
- Tractor
- Kioti LK2554, Branson 4815C, Satoh Beaver, Speedex
How much free play do you have with the pedal? You measure this by pushing the clutch in till you feel resistance. You want about 3/4“ to 1” of movement. If it is more than that then you can adjust the linkage to get it into range. The linkage is external and easy to get to.NO sir. The high low shifter is not in neutral. It seems way worse when operating in the high range. ANY incline will make the tractor come to a stop. Throttle increase has no effect. If I use the low range i can get it to start moving, but it is very slow. Like it is spinning up and then begins to slowly move. trying to make the clutch adjustment, but i cant see how to get to the locking nut on the adjustment screw for the clutch.
If it is within range then you are looking at splitting the tractor and replacing the clutch. The only other thing you can check to make sure it is the clutch is mark the back tires to a spot on the rim. There have been quite a few people running liquid ballast in their tires and the rim starts spinning in the tire. This mimics a clutch issue. It also is hard to detect from the tractor seat so mark the tires then try to drive the tractor. If tractor does not move, stop and check the marks. If they still line up you need a clutch. If the marks moved you need to put more air in the tire.
