Which Wisconsin V4 engine has distributor on top of engine under the carb?
   / Which Wisconsin V4 engine has distributor on top of engine under the carb? #1
Dunno
Ford
Hi,
I'm looking to buy a spare engine for my stump grinder which has a Wisconsin W4-1770 35hp on there. A Wisconsin engine came up for sale and I can't figure out which model it is, and seller doesn't know. The most distinguishing feature I see in the pics is that the distributor is on top of the engine at a 45 degree angle under the carb. I've read a WG4D will fit where the W4-1770 is, and I think this might be one, but hopefully someone knows which V4 engines came with that top-mounted distributor. Thanks. John
   / Which Wisconsin V4 engine has distributor on top of engine under the carb? #2
A VH4D (<-- like in my Bobcat) would be a closer match, but it has the distributor on the side of the engine.
Here's a bunch of literature on the various versions of engines they made, hopefully something shows up.
Hi Dan,
Great source of Wisconsin literature, thank you. So, if the engine with the top mount distributor is a VH4D, from the literature the size specs of the VH4D and 1770 are the same, so I assume should fit? My -1770 has the side mount dizzy, which is how I knew the one for sale was different. Thanks.
   / Which Wisconsin V4 engine has distributor on top of engine under the carb? #4
I wonder if it was even a Wisc for sale...I don't recall ever seeing one with a distributor on top, and once they settle on a casting they usually stick with it throughout; eg. Fords have front mount dists, GM and Mopar on the back, etc.
   / Which Wisconsin V4 engine has distributor on top of engine under the carb? #5
I have two with magneto's.
   / Which Wisconsin V4 engine has distributor on top of engine under the carb? #7
Ford 8n's had them on the front and moved them to the side.
SR
Does anyone know what model of Wisconsin V4 is pictured? I looked at my 1770 but it does not seem to have the provisions to mount a distributor in that position. Thanks.
John
Airbuscuit,
That looks to be the same model as it has the distributor in the same place. Do you know what model it is? Thanks.
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
72in Hydraulic Dozer Blade Skid Steer Attachment (A55787)
72in Hydraulic...
2001 International 3800 DT466E (A53314)
2001 International...
2010 Nissan Rogue SUV (A53424)
2010 Nissan Rogue...
2015 Ford F-250 Knapheide Service Truck (A55788)
2015 Ford F-250...
PAINT ROOM EXHAUST FAN (A54757)
PAINT ROOM EXHAUST...
