How to prevent locks from freezing.
/ How to prevent locks from freezing. #4
TBN member hunt4570 found another solution... He moved to South Carolina! :D
Hmm. That might not always work, moving south. 😁. I was out in the yard this morning with a hairdryer thawing the pipes on my well. We go into near panic mode if it goes below 25 degrees or so. It got down to 20. 🥶🥶🥶
/ How to prevent locks from freezing. #6
I have a couple locks. They ARE under cover. Helps keep them from turning into an ice cube. Still have occasional frost problem. Heat key with lighter - insert while hot. Usually solves problem.
Up to +27F now. Things are getting soggy.........
/ How to prevent locks from freezing. #7
We can't get those normal butane lighters to work in cooler weather.
/ How to prevent locks from freezing. #8
I hail from northern Vermont, a little north of Stowe.
I'm retiring to Mississippi and thought I solved the freezing problem.
NOPE
I've had a 20x40 Versatube Carport collapse, I attribute that to ice build up from back to back record ice storms.
I've had outside plumbing freeze and cause a geyser (amazingly I caught it when I was here, 50% of the time I'm in Virginia).
And this week it got down to 4°F and I've an outside extension to the water line I had put in that sticks up and is subject to freeze.
My solution for the potential freezing pipe was to order a heat tape from Amazon, but it wouldn't get here in time. For the 4°F problem yesterday I wrapped a heating pad in a plastic bag and plugged it in on medium, then wrapped that around the pipe, encased it all in a short section of 4" drain pipe and covered it with a feed tub. Really MacGyvered but worked fine.
/ How to prevent locks from freezing. #9
I carry mine in an inside pocket. You are right though, they don't like being cold. I also carry a Zippo all winter, although they aren't as "windproof" as the name implies.
/ How to prevent locks from freezing. #10
We do the same thing, but once that butane cools, you got nothing...... Lock oil is your freind!
/ How to prevent locks from freezing. #11
Oh, for that I carry a can of deicer.
And a propane torch.
I just like having the ability to start a fire in winter.
WD40 works well.
WD40 just wasn’t cutting it for me. It still would freeze up. And it seemed to wash out of the lock after a good rain.
/ How to prevent locks from freezing. #14
I have one gate lock which is filled with ice after every rain storm followed by cold temps. I thaw it, leave it on the truck defroster until it gets so hot you can barely handle it; and put it back on so that I can do it again next time after spraying it with various lubricants. Nothing I have tried seems to help, although I am not ready for the B&C mess which the OPs link describes.
Ya to me its what ever aggravation you want to put up with :)
/ How to prevent locks from freezing. #16
Hmm. That might not always work, moving south. . I was out in the yard this morning with a hairdryer thawing the pipes on my well. We go into near panic mode if it goes below 25 degrees or so. It got down to 20.
Do you have a well house? We do and I discovered a solution it will help you or someone else since I had years of frozen pipes. Get some reflective foam insulation panels, one side is mirror-shiny. I put a light socket in well house with 60 Watt incandescent bulb. Panel cut to fit, mine is cinder block, top tilts up. Panels reflective side down. This morning I checked and lifting a panel it was toasty warm, I'm guessing 60°F and 9°F outside.
/ How to prevent locks from freezing. #17
These small butane torches I use for locks & frozen latches. It works even if not too windy.
I've used it to solder wires together, adjusted low.
/ How to prevent locks from freezing. #19
I've used it to solder wires together, adjusted low.View attachment 776283
I'm not sure where temperature you are working in but butane does not atomized or whatever its called, to create a good flame at lower temps, like below 40.. This is common knowledge with people who camp in the winter.
/ How to prevent locks from freezing. #20
I don't know about zero, but I used mine yesterday at 9°F and it worked.
2018 RoGator 1100C (A63118)
2018 RoGator 1100C...
HARDEE LR40148 DITCH BANK CUTTER (A63745)
HARDEE LR40148...
John Deere 5101E Tractor w/ John Deere Loader (A64047)
John Deere 5101E...
Adams 5T Spreader (A63118)
Adams 5T Spreader...
20ft trailer (A61569)
WABBLE BOX & HYD PUMP (A63745)
WABBLE BOX & HYD...
