Looking for TWO Recommendations: 1) Thermal Imager; and 2)WIFI Booster/Network Extender
   / Looking for TWO Recommendations: 1) Thermal Imager; and 2)WIFI Booster/Network Extender
That looks close to what I was getting with Hughesnet. I got the "best effort" from starlink and it varies a lot but even the low end data rate is significantly faster. This mornings speed is a little slow, I've seen it up around 100 most times.
I am still on the Waiting and Waiting List for StarLink.
Depending on what kind of cell coverage you have you may check with your cellular provider on what hot spot device package they offer. We are using a Hot spot box from Verizon, both the wife and I work off of it all day and have not issues. I got rid of my local ISP because in rural areas they often suck.
I second's @hiddentacocatneddih recommendation of the Mesh. I have a 3 node Mesh and love it. I was having issues with coverage in our brick home and tried expensive routers with supposed great coverage and had issues with them until I got the Mesh network. The main node is in my wife's office then I have a node in my office and one in the main living area.
I have this one
My cell coverage is marginal at best
   / Looking for TWO Recommendations: 1) Thermal Imager; and 2)WIFI Booster/Network Extender #14
Out here there is no cell coverage but the local phone co is pulling fiber to every address. Hope to get it next year. Until then I have 30 mbs down and 3 up.
   / Looking for TWO Recommendations: 1) Thermal Imager; and 2)WIFI Booster/Network Extender #15
Those are respectable speeds. I only have 20mb down and it serves our needs just fine. No gaming in this home, but we do watch only streamed TV.
Are there any tower based providers?
Verizon, AT&T and their hangers-on. . .
terrain-wise, we are in a very “folded” topography, and a lot of pine needles to interfere as well.
ALLEGEDLY we are getting fiber. . . But the “allegedly” has been for more years than we have been here. . .
I just got an email from StarLink last night (that I didn’t see u til now) that I can get the “best Effort” service — is it worth it?
   / Looking for TWO Recommendations: 1) Thermal Imager; and 2)WIFI Booster/Network Extender #18
Our local tower company has a wifi/internet deal. I wasnt lucky enough to use them due to LOS issues
   / Looking for TWO Recommendations: 1) Thermal Imager; and 2)WIFI Booster/Network Extender #19
Best Effort means you will be the first to be throttled during congested use. Most times it should be fine unless you are doing serious gaming or streaming to more than one TV. Although "3Ts" can tell you better how it actually works, I have regular "Residential Starlink". At first I saw download speeds in the 125-150Mps range, now it rarely goes over 100, most times it in the 40-80 range which is plenty fast enough for our uses. Biggest issue I had with Starlink was finding an area large enough that was clear of trees to get a good signal to the north-northeast of where I mounted the antenna. If you download the Starlink app it has a function to look for obstructions to see if you have enough clear area in the right direction. The app is not intuitive to use, but you do need a smart phone to use it.
   / Looking for TWO Recommendations: 1) Thermal Imager; and 2)WIFI Booster/Network Extender #20
As far as thermal imaging goes. I have a FLIR model. $600. Separate unit with a standard camera AND the thermal imager. This means you get a thermal image with the actual object ghosted around it. This means you can tell what you are looking at.
Bought it to check the house insulation, arthritis in the dogs (hot spots), breast cancer in the spouse, and this ALL paid back the cost. Best one was finding I had a built-in surge suppressor in a wall feeding the computers, chargers, and printer. I saw a PURPLE image behind it and when I pulled it out it burned my hand. Capacitor was nearly on fire.
Most intriguing use was to locate moles in the lawn at night in real time. Holy tunnels, bat guy, What a super highway ! Had to reload TWICE.
2008 Ford Focus SEL Sedan (A55853)
2008 Ford Focus...
Massey Ferguson 9250 (A55302)
Massey Ferguson...
New/Unused SD Lanch SDLE20 Mini Excavator (A54865)
New/Unused SD...
2005 Sterling L7500 Fuel and Lube Truck, VIN # 2FZHATDC95AV42993 (A54865)
2005 Sterling...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
