Snow Conn Power Outages
Status
Not open for further replies.
/ Conn Power Outages #1
AndyMA
Elite Member
Windham County, Conn
Ford 2120 , Kubota MX5200 , Deere X748SE. 1956 Economy Tractor
Wide Spread Outages
/ Conn Power Outages #2
Yikes! Have a cousin in Western CT. I'll have to send her a text and see if they are OK.
Thanks for posting this.
/ Conn Power Outages #3
Storm blew through Pittsburgh Pa and blew the top off one of our trees here. About a 20ft section of dead pine. Power was out the whole day and came on just as sun set at 5pm. Whew. Dodged that one as it's currently -3.8 outside. Inside house temps were down to 64 degrees.
/ Conn Power Outages #4
haha....my wife keeps our house at 64 in the winter anyway. Got to boost it up to 68 this week to help in case pipes froze. 20 years ago, it was me trying to save money and keep the thermostat low! It is even worse, since the way our thermostat is set up, the majority of the house is a good 3-5 degrees colder most of the time.
/ Conn Power Outages #5
Not an issue here as we have a diesel powered standby. 45 seconds and it assumes the entire load. Something I'm never concerned about.
/ Conn Power Outages #8
Old man winter gave lot of us 1-2 punch.
/ Conn Power Outages #9
OK I understand that you got snow an some wind. Did that take down the power lines or was the system overloaded caused blackouts ?
/ Conn Power Outages #10
We got a notification from AEP Ohio to reduce power usage and that load shedding may need to occur to protect the grid. My niece lives in a little town in Logan county and half the town is out because of load management. Bad time to be without power.
I would never trust just electric for heat. Never. Always have a non electric backup that could sustain you at least a week. Even better a month.
/ Conn Power Outages #12
If they part of the PJM transmission organization it may be a controlled blackout. Ohio is PJM and we just got the heads up earlier that they were possible.
/ Conn Power Outages #14
OK I don't know how the electricity in your area is being generated, but if it's like a lot of other cities and states, a lot of it is "supposed" to be generated by wind and solar. If you have high winds and it's night time, and it's cold, the wind generators are shut down and of course there is no sun. So much for the "renewable" energy. It just doesn't work.
/ Conn Power Outages #15
Except most places in California are not 5 degrees
Far as I'm concerned, California's issues are 100% self imposed
That is because PG&E is more concerned on paying dividends on their stocks then putting utility payer's monies back into the system.... But dark is dark and cold is cold...
/ Conn Power Outages #16
Coal and Nuclear primarily with some Hydro, Solar and Wind for PJM.
/ Conn Power Outages #17
There should be extra capacity available since many heavy industries shut down for the holiday such as steel mills and aluminum smelters
Status
New Holland 256 Hayrake (A66408)
New Holland 256...
2009 Kershaw 75-G2 Sky Trim (A65579)
2009 Kershaw 75-G2...
2012 PETERBILT 386 (INOPERABLE) (A65643)
2012 PETERBILT 386...
New/Unused Landhonor Mini Skidsteer (A65583)
New/Unused...
2006 GMC Savana 3500 Box Truck (A61573)
2006 GMC Savana...
Peterbilt 377 Semi-Truck (A63689)
Peterbilt 377...
