Kubota L3250 Knocking sound
   / Kubota L3250 Knocking sound #1
Hhinai4
Kubota L3250
Hi team,
I have Kubota L3250 i had over heating, i replaced water pump, head jasket and radiator cleaned, now it’s working fine. But i have knocking sound after gead jasket
replacement. Valve adjusted as per manual, and also i replaced new original injectors but the sound still there. If you guys have experience please share. Link for the sound attached.
Thanks
   / Kubota L3250 Knocking sound #2
That doesn't sound promising. perhaps a bad or spun bearing that needs attention. if it were me I'd pull the pan and check rod bearings.
This sound only came once head gasket replaced, might be tapet or air inside fuel injection
   / Kubota L3250 Knocking sound #4
I would pull the fan belt and try it. I have had belt tensioners make that sound.
I will pull fan belt, i hope that would be the issue
   / Kubota L3250 Knocking sound #6
Loosen the injector lines 1x1..
Loosen, tighten up, move to the next..
That will narrow it down to “A” cylinder..
Next, swap the injector to the hole furthest away..
If it stays on the original cylinder at least u know where to go from there.
I have replaced new original injectors, so you think i have to swap the injectors?
   / Kubota L3250 Knocking sound #8
Just because it's new does not necessarily mean it's good. Things are certainly not made as well as they used to be
   / Kubota L3250 Knocking sound #9
Do u know what cylinder is knocking.??
Loosening and tightening the line will narrow it down..
THEN swap the injector to rule it out..
Btw.. internet injectors r usually junk..
2016 POLARIS RANGER ETX EFI 00HC RTV (A51243)
2016 POLARIS...
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
John Deere 922 Platform (A50514)
John Deere 922...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
Woods 3180 Batwing Mower (A50514)
Woods 3180 Batwing...
