John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,643
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
No damage to splines that we could seeDid you see anything that would have caused the loss of drive after the "pop"? Like damaged splines?
Yes, as mentioned in the post that included the picturesI see some of the break was rusted so it had been cracked for a while.
Have you contracted any welders to have it welded back together? I have a 60 HP 4 Wheel Drive tractor welded back for $1,700. They had to pull it in half weld it up and bolt it back. The guy did a fantastic job. I have no idea what caused mine to break. I have seen on some forums that the bolts weren't tightened from the factor. But those guys were just chatting about loose bolts, their tractors didn't break in half.
I discussed that with a local welder. He is really good at what he does, and has done a good bit of welding on castings (including some for me). Whether he welds it or I replace it, the tractor needed to be pulled apart. A used clutch housing costs $1000. His recommendation was that for the price, since it had to come apart anyway, a good used one would be the way to go. He was concerned that welding the casting back together in what is obviously a highly stressed part could lead to further breakage.
