Gasoline Tractors are they coming Back ?
   / Gasoline Tractors are they coming Back ? #91
Interesting to read on how you guys the other side of the pond are still going for petrol [gas] engines. Here I don't think I've seen a new tractor that runs on petrol or petrol/parraffin [kerosine] since the 1960s. Back just after WW11 many in fact most farmers had petrol or petrol/parraffin, that you switched over too when the engine got warmed up, A lot of the tractors came from your side of the pond. Most diesels at that time were a pain to start in the cold. That was until MF brought out the little MF35 later 135 and the MF65 and 165. On reading your posts, no one mentioned running on parraffin [kerosine]. Here in England it's nearly the same price as petrol at the pump. They say its because of there's no demand. Loads of rubbish, what are all those aeroplanes running on, I guess our government don't want us simple minions using the stuff. Electric tractors, no not seen one, Theres plenty of motor cars, but our government has just altered the tax system so they now have to pay more tax. As governments do after they have convinced every one to buy one. Weve got a small fishing fleet in my town, Non are on electric, all diesel. some like your Caterpiler engines, others go for Perkins and Ford. Interesting I see a lot of ships now use electric drive motors driven by diesel generators. Years ago there was a massive crane/drag line not far from me. It was run on by electric, but it was connected by an electric cable. If only they could make an electric unit that didn't have to drag the battery onlong. As an add on, I run a diesel tractor and a three year old diesel Mercedes car.
   / Gasoline Tractors are they coming Back ? #92
Diesel started becoming more expensive than gas in the early 2000s when the switch was made to ultra low sulfur diesel. The price differential with gas is a larger spread now than it used to be.
Yes, they have to pay the guy with a pair of tweezers who picks out each sulfur atom. Next thing will be to set him to picking out the carbon atoms as well.
   / Gasoline Tractors are they coming Back ? #93
I seriously doubt it. They will go to electric.. unfortunately. The problem with electric and gas is the run time and torque. Think about it. There is a reason all of the major brands aren't making gas tractors anymore. They just can't keep up. That's not referring to the old ones, but the life you will get out of a gas engine and the torque cannot meet today's power demands. Yes these bigger gas engines are impressive, however, getting 14MPG in a brand new truck is very disappointing to say the least.
   / Gasoline Tractors are they coming Back ? #94
Having owned both gas and diesel tractors for years and put lots of hours on both, there ain't no way you could talk me into buying a gas tractor again for numerous reasons. I think a lot of people are comparing the simplicity of a 1960's gas tractor engine to the complexity of a modern diesel tractor engine. A modern gas tractor engine would likely be just as complex as a modern diesel engine, but likely have a much shorter life cycle and have a higher fuel consumption rate per ft lb of torque. Same as in the '60's.
The $2 per gallon diesel vs gasoline cost difference on average would be a fairly sizable exaggeration where I live. Off-road diesel vs regular gas is currently less than half that difference. Taxed diesel is around $1.50/gallon more expensive, but I never buy that for my tractor. And we are in an anomaly at the moment, it usually isn't that great of difference.
Couldn't have said it better .
   / Gasoline Tractors are they coming Back ? #95
The issues I can see revolve around getting the same power out of the same size/weight engine reliably and inexpensively with a gasser as with a modern common-rail turbodiesel.
A modern EFI gasoline engine is pretty close to the same efficiency in HP-hr/lb as a current Tier 4 diesel. Gasoline engines can be built just as heavy as diesel engines and have a similar lifespan. Off-road gasoline engines have minimal emissions requirements, and even if they had to meet on-road emissions, those are still much simpler and less expensive than those of a Tier 4 diesel. At least regular 87 octane gasoline is also noticeably less expensive than diesel so your costs per HP-hr would be lower with regular gasoline if it could be done.
A naturally-aspirated gasoline engine running on 87 octane makes only a little more power (about 15% or so) at the same RPM than a naturally-aspirated diesel of the same displacement. The issue is that a highly-tuned four-valve multiple-turbocharged and intercooled/aftercooled diesel can make twice the HP/displacement as it would naturally-aspirated, so you would either need a much larger naturally-aspirated gasoline engine to make the same power or add forced aspiration to the gasser. Adding forced aspiration would either bring direct injection into the mix (which brings extra cost and some reliability issues) in order to continue to run 87 octane gasoline or you would need to run a much higher octane fuel to avoid needing direct injection. The limited market for turbocharged heavy duty non-diesel engines with similar power densities as the highly tuned turbodiesels is solidly in the "higher octane fuel" camp as they run on 106 octane propane or 120 octane methane. All of the industrial engines I've come across that run on gasoline are naturally-aspirated.
The efficiency that you claim for the gasolines engines isn't present.
   / Gasoline Tractors are they coming Back ? #96
You can buy a 40HP Briggs Vanguard EFI engine in many high end commercial mowers and it makes more horsepower and more torque than say a 25hp diesel small tractor. Why not?
   / Gasoline Tractors are they coming Back ? #97
If your lucky to live near a dealership That sells racing fuels you can get gas from them. Hi test and no dang ethanol. Also I live near a small airport and they sell good gas with no ethanol. Only thing it's not cheap which is why it's hard to not go diesel for a lot of work. But this post gives me urge to post my Sunday go for picnic ride tractor. LOL Grabbed my Grandads old 41 B and tore her apart and gave her a new look. If you use good gas and shut off the petcock to keep gas out of the carb you have no problem firing it up and running. Except maybe the new fangled carbs are too sophisticated to do that today. But so far all my small gasoline implements work good using that technique.
Before and After:
   / Gasoline Tractors are they coming Back ? #98
I would watch what Cummins Engine Co is doing for research. Elect will only work with light loads, coasting and regen braking - not something tractors do.
If the majority of cars go electric, the availability of gas will decrease and the price will go up and then be equivalent in price to diesel, yet 30% less efficient and still have poor storage life and a explosion hazard.
   / Gasoline Tractors are they coming Back ? #99
I don't see any great advantage to today's diesels.
Diesel fuel it offers drivers a better bang for their buck than gasoline. People concerned about fuel efficiency should strongly consider diesel engines.
Diesel engines not only deliver better fuel economy than similarly performing gasoline engines, but they also deliver as much or more fuel economy as gasoline-electric hybrids. This is due to the diesel engine’s superior torque and energy. These factors also contribute to the diesel engine’s impressive speed.
A diesel engine requires fewer repairs. A diesel engine does not need spark plugs or distributors, which are common pieces of maintenance required for traditional internal combustion engines. Avoiding these bothersome visits to the mechanic could save a car owner a tremendous amount of money over the years.
A diesel engine, known for its durability, will experience less wear than a gas engine.
Diesel engines offer riders a faster start than gas-powered engines. This is due to its torque. Essentially, diesel engines provide far more torque to the driveshaft, which allows them to go from zero to double digits quicker than a gas car.
One of the biggest advantages of a diesel engine over gasoline is resale value. Since diesel engines are more durable, they retain their value much better than gasoline engines.
- Stolen and paraphrased from Advantages of a Diesel Engine Over Gasoline
   / Gasoline Tractors are they coming Back ? #100
They'd run non stop for several hours twice a day. Start/stop/change direction, power the lift pumps. It was not easy work. Much harder than the load on a car.
You’re right about the electric Hilo but it’s job can’t be compared to a tractor running pto equipment at high rpm for hours on end. I don’t see a battery tractor having a significant role in a true farm operation. For folks that use a tractor just around the yard or for odd jobs the battery might be a practical option
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55302)
2019 Krause...
2002 Wacker RD11A Tandem Smooth Drum Roller (A54811)
2002 Wacker RD11A...
1979 MACK R MODEL (A53843)
1979 MACK R MODEL...
2009 Ford F750 Reel Loader Truck (A52377)
2009 Ford F750...
PALLET OF (2) GRACO AIR COMPRESSOR (A54756)
PALLET OF (2)...
