Is a "hybrid" barbed wire fence more friendly to wildlife?
   / Is a "hybrid" barbed wire fence more friendly to wildlife? #1
plowhog
Elite Member
North. NV, North. CA
Massey 1710 / 1758, Ventrac 4500Y / TD9
I need to add fencing near a neighbor who is doing things to make me want that. It's about 1,000 feet of fencing total.
For strength, I'm considering wood posts at end points, and also periodically along the run. The rest will be metal T-posts. 4' high.
My wife is concerned about wildlife and deer. So she is suggesting a "bare wire" for the top wire. Then used barbed wire for the rest.
Does putting a "non" barbed wire along the top make it a little more friendly for animals that jump?
   / Is a "hybrid" barbed wire fence more friendly to wildlife? #2
Over the yrs I have seen deer caught in all types of wire fence. There are just some deer who insist upon being culled from the genepool this way. What is it you are trying to fence out with a 4ft stranded fence?
   / Is a "hybrid" barbed wire fence more friendly to wildlife? #3
Forest Service insists on a bare wire on the bottom strand I guess so coyotes, bunnies and such don't get scarred
   / Is a "hybrid" barbed wire fence more friendly to wildlife? #4
Please "snag" all the coyotes you can, with that fence. ;)
Deer can jump over a 4' fence without trouble. If it's barbed and the spacing is wide enough, little critters will crawl through fine. I wouldn't bother with a top wire.
   / Is a "hybrid" barbed wire fence more friendly to wildlife? #5
So, after reading some of these post, just use bare wire? If you are just "marking" your property line, seems like bare wire would work, easier to handle, quick to put up. Animals slip through easier.
   / Is a "hybrid" barbed wire fence more friendly to wildlife? #6
Depends on what you are trying to fence in/out. If just marking the boundary so the neighbors know, I might just run two barbless strands. Barbless is easier to work with and can be a little wildlife friendly. Wire spacing is almost as important as wire type, so they don't get a leg entangled in wires too close together. Barbed wire is used mainly for cattle, works for horses but not much else. Personally I used 3 strands of barbless for a horse pasture and it worked fine.
If wanting to contain or exclude some other types of animals, field fence is best. But a lot more expensive. Deer can easily jump over 4 ft fence. They even manage to clear the 6ft fence around my garden sometimes.
People can and will cross through any type of fence, unless its electric with no obvious gates or other ways through.
I have some neighbors I don't much appreciate. I found just clearing the line and installing t-posts worked well to let them know not to casually cross onto my land. But if I want to keep their dogs out or the goats when they escape I will eventually need a field fence.
Heavy wood posts for the ends. Preferably an H-brace and wood posts every 200-300 feet is recommended. I managed to get a hold of several old power poles and cut them to 8 ft. They make great fence corners and brace posts.
A new neighbor is encroaching across the property line. I need to get his encroaching items back onto his own property and then fence it to make the property line very visible and stop further encroachment. Oddly, this property line is well marked and flagged. Just a disrespectful neighbor.
Very good suggestion. I have some old power poles laying around and they will be put into service!!!!
   / Is a "hybrid" barbed wire fence more friendly to wildlife? #9
The newer poles are not good for reuse. The preservatives are designed to quickly leach in soil and provide barrier. Doesn’t work for reuse
   / Is a "hybrid" barbed wire fence more friendly to wildlife? #10
Oddly enough, we had a young deer get caught in a woven wire fence yesterday. By the time I saw it, it was already dead. So, barbs were not an issue.
   / Is a "hybrid" barbed wire fence more friendly to wildlife? #11
Been out here 40+ years. NEVER seen nor heard of wildlife being hurt by barbed wire fencing. I have my 80 acres enclosed in barbed wire fencing - mile and a half of it. Turnbull National Wildlife Refuge - just across the county road - uses barbed wire. EVERY county road has barbed wire up/down its full length - both sides. Keeps the cattle where they are supposed to be.
What the Hell - everybody out here uses barbed wire and T-posts.
The idea that wildlife will become injured on barbed wire - an old wives tale.
   / Is a "hybrid" barbed wire fence more friendly to wildlife? #12
Seriously? Do you live under a rock? Fire up google search and punch in " pictures of animals caught in barber wire fence. :rolleyes::rolleyes::rolleyes:
   / Is a "hybrid" barbed wire fence more friendly to wildlife? #13
I wonder how barbed wire compares to automobiles when it comes endangering wildlife?
   / Is a "hybrid" barbed wire fence more friendly to wildlife? #14
If the encroaching items are on your property I guess you can "clean them up" and make them disappear I bet that solves the problem.
   / Is a "hybrid" barbed wire fence more friendly to wildlife? #15
Put your fencing in now, then let him/her come over and try and get the stuff back...
   / Is a "hybrid" barbed wire fence more friendly to wildlife? #16
So far one deer and one woodchuck on this farm caught in barb wire in 30 years. wish would happen more. To many of both
For boundaries barb is great. Smooth wire he could just keep coming through. Easy enough to walk through. However, you could add electric as well to your new fence to keep things interesting.
   / Is a "hybrid" barbed wire fence more friendly to wildlife? #17
Good fences make for good neighbors We use 3x4 wire mesh 5 ft high. 1.5" pipe post every 8' with a top rail.
   / Is a "hybrid" barbed wire fence more friendly to wildlife? #18
Come on scootr - do you honestly think where I live makes a hill of beans of difference. The fact of the matter is - animals learn very quickly about barbed wire. Or maybe those in CA just aren't so smart - HuH??? Around here the deer & elk go over. Coyotes, raccoons, badgers - and the like - squeeze under. Moose will just step over. Cows stand on the other side with a stupid look on their faces.
   / Is a "hybrid" barbed wire fence more friendly to wildlife? #19
Oh yeah, CA wildlife is stupid :p
   / Is a "hybrid" barbed wire fence more friendly to wildlife? #20
I have heard of animals caught in fence, but not heard specifically that barbed wire was worse than other type. Only exception is horse that ran through barb wire fence, she was cut bad enough to be put down
2009 Ford F-550 4x4 Ext. Cab Brush Fire Truck (A59230)
2009 Ford F-550...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
2016 Freightliner Bucket Truck with Altec LR756 (A56438)
2016 Freightliner...
1995 John Deere 7400 (A60462)
1995 John Deere...
2012 CATERPILLAR 257B3 SKID STEER (A60429)
2012 CATERPILLAR...
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
