Unsafe generator wiring et al.
   / Unsafe generator wiring et al.
I doubt that. You have to remember everything is going to be turning on at nearly the same time.
When the power goes out I don't turn everything on. In fact I try to turn everything off except for what I am powering with my generator. And even then I don't turn everything on that I can. When your power goes out do you turn everything on? If so then why? Most of the time people don't have most everything turned on because it costs money. So I'm pretty sure that the two homes downstream from me could also be powered by my generator at the same time my house is being powered. I only have a 7000 watt generator because it was serendipitously given to me after my 3000 watt generator failed, and even that generator was more than I needed.
Eric
   / Unsafe generator wiring et al. #22
But mostly, the people that do this stuff lack knowlege.
Oh they may have knowledge, but knowledge without wisdom or good judgement is dangerous.
   / Unsafe generator wiring et al. #23
Eric
I'd guess that when there's a power outage, most people get up, look out the window to see if it's just them or the neighborhood, maybe find a flashlight, and try their phone to call someone else to see if their power is out as well. They do NOT go around and turn everything off in their house.
   / Unsafe generator wiring et al. #24
i just sit where i am for 30 seconds...generator starts up, auto transfers and im back in business. if im watching tv, i dont even stop watching as the tv and sat/wifi are all battery backed UPS systems. i LOVE my creature comforts.
   / Unsafe generator wiring et al. #25
I'm not condoning the practice.
Neither am I. In fact, I had a professional electrician hook up my diesel powered 30KW standby genset. I don't do electricity well. Plumbing not so much. With plumbing, if it leaks you get wet. With electricity, if it leaks, you get dead.
Back feeding to the utility pole is a very distinct possibility and I certainly don't want to electrocute a power company employee.
   / Unsafe generator wiring et al. #26
This was posted by Moss. Simple and no chance of generator breaker on, main on simultaneously.
My experience is most all accidents are doing something different, something you do once every 5 years or so.
We lose power maybe that often, and the generator I have I should sell. I used it once in 10 years and try remembering to start it once a year (carburetor).
Neighbors had a Generac system installed. Concrete pad poured, a 500 gallon propane tank, line trenched to house with automatic switching. I'm sure all that was expensive.
It runs automatically about once a week for about 15 minutes. Total waste of money in my opinion.
Last time we lost power it was for an hour.
   / Unsafe generator wiring et al. #27
It all boils down to luxury, necessity, affordability, etc., and what someone can justify in their own mind as to what they need VS what they want.
27 years ago we bought our current house in the county that is on a well. I vowed that I'd not make my wife do without a working toilet in a power outage, so I bought a generator before we even moved in.
Since then, I can think of maybe 3 times that I broke it out when a power outage lasted longer than 4 hours, and the pressure tank had been drawn down enough and the pool was frozen so I couldn't grab a bucket of water to flush the toilet. So I fired it up, flushed the toilet, recharged the pressure tank, ran the refrigerator/freezers, the deep freeze, and shut it down again. We have a wood burner for heat if needed.
Same goes for my in-laws. A couple times they've been without power for 3+days, so I'd run it for a couple hours, fill the bathtub with water to flush the toilet, let them take a shower in the other bathroom, recharge their fridge and freezer and shut it off. They have a wood burner as well if needed.
So, the $400 generator sits and waits. Called upon if needed. But in reality, we could do without it if needed. Worse comes to worse, I can tie a shot glass to a string and fish the well. :ROFLMAO:
I cannot justify the money for a standby generator that might not ever get used, when we know we can get by just fine on a little portable.
Kinda funny, even though we have the money to do it, we just have an actual aversion to it. I guess that's the depression-era parenting we received. :)
Not begrudging anyone that does have one. It sure is nice. But seems kinda like a boat or camper or vacation home that only gets used once or twice a year. I'd rather rent.
   / Unsafe generator wiring et al. #28
most of my customers are on wells, with animals. backup generators are not a luxury, there a necessity. livestock can get sick and dye pretty fast with no water. Same with people that have small chicken coups when they lose heat. today its 14F outside, snowing and damn cold windy.
no one will pry my generator from my warm fingers.
City folk dont need them, but i do have some clients that have them due to health reasons.
   / Unsafe generator wiring et al. #29
Please don't misconstrue what I'm about to ask........
But lets say, you have a 4400 WATT generator, and for some reason you use a suicide cord and forget to switch off the main. And lets also say that all your neighbors do exactly the same thing during an outage. Wouldn't the non-synchronized generators cancel each other out? They would all be out of phase.
   / Unsafe generator wiring et al. #30
But lets say, you have a 4400 WATT generator, and for some reason you use a suicide cord and forget to switch off the main. And lets also say that all your neighbors do exactly the same thing during an outage. Wouldn't the non-synchronized generators cancel each other out? They woulds all be out of phase.
Something like this...
2011 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A59904)
2011 INTERNATIONAL...
Parker 6255 Gravity Wagon (A59814)
Parker 6255...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
Electric Golf Cart (A56859)
Electric Golf Cart...
1996 Sunflower 1543-38 Folding Disk (A56438)
1996 Sunflower...
Brillion 3Pt  5' Seeder (A59814)
Brillion 3Pt 5'...
