S854
- Joined
- Dec 5, 2017
- Messages
- 958
- Location
- Helena, MT
- Tractor
- ‘67 MF 135 Deluxe / ‘22 Kioti CK2610 HST/Bad Boy ZT Elite 54”
Reading through the owners manual of my new tractor (Kioti CK2610 HST, if it matters) I came across a couple of "torque tightening charts", one for metric, the other for ISO...the charts list "bolt sizes" and "grades"-- along with the minimum and maximum torque for each...
Other than the required torque on the wheel lugs, there is no other torque specs in the manual... I looked online for a service or repair manual and came up short...
I went to a website (BOLTDEPOT.COM) and came across a subheading--"BOLT HEAD/WRENCH SIZE"--which lists, for example, a "10mm bolt" which requires a "14mm" wrench... I could then assume the 14mm bolt head on my tractor would correlate to an M10 bolt... find the M10 torque specs in the manual and go from there... (I'm sure the whole process would take much less time to actually perform and it would take to read and understand my methodology...
This seems like a rather convoluted method of coming up with the correct torque wrench settings for the various fasteners I'm checking, but if it works... what the heck, eh?
I'm thinking I'll double-check the fasteners before going full in... I.e. back out one of the bolts and measure the shank diameter, then compare this with the bolt head/shank size listed on the "BOLT HEAD/WRENCH SIZE" chart... (reading the bolt grade on the bolt head is a no-brainer)...
Does this method make sense?
