Mahindra 3510 PTO
/ Mahindra 3510 PTO #1
jimmycrouch
Mahindra 3510
Does the PTO just spin in one direction. Is there not a forward and reverse? Example: on a digger attachment can the blade spin forward and then in reverse to remove the bit from the hole and spin the dirt off of the bit?
/ Mahindra 3510 PTO #2
Your PTO spins in one direction only. I suspect a specialty machine exists that can spin the pto both directions, but I have never heard of one.
A hydraulically powered auger can turn either way, which is a huge advantage when drilling holes. If you bury the auger on a pto powered unit sometimes the auger must be removed from the implement and spun out by hand with a large pipe.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59909)
2016 FREIGHTLINER...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
NexTier Frac Manifold T/A Trailer (A60352)
NexTier Frac...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
New/Unused Landhonor Transfer Pump (A61166)
New/Unused...
