Better Radio For The LS MT342
   / Better Radio For The LS MT342 #1
KCTractors
Wi
LS MT357, Case 530 CK, , Ford 2000, , Ford 8N, Moline 602
The radio the LS Dealer installed in the cab of the tractor has all the features you could want but you can't see the read out on the screen.
Did anybody install a better radio that you can see what you are doing with the radio with out breaking the bank. I basically want to pair my phone in the radio.
   / Better Radio For The LS MT342 #2
I want a radio that will pair with my Bluetooth headphones. The cab is so noisy, the radio speakers are useless.
   / Better Radio For The LS MT342 #3
I'm not sure if they upgraded the speakers in the MT3 over the old XR. Probably not. That was one of the first things to get replaced in my tractor. I put some larger speakers in, had to cut some plastic, but sound is much MUCH better.
As for the head unit, I went with this Pioneer
It has Bluetooth and is bright enough to see at that awkward angle. I have yet to have an issue with it.
   / Better Radio For The LS MT342 #4
Or maybe it is time to upgrade the eyeglass prescription. 😁
   / Better Radio For The LS MT342 #5
Thanks for the link to the Pioneer.
Do you know if it will stream audio output to Bluetooth headphones?
   / Better Radio For The LS MT342 #6
Typically car stereos do not stream music to other devices. At least, I couldnt find any. You might be better off with a simple bluethooth headphones and a smart phone. Pair them and stream directly from your phone.
   / Better Radio For The LS MT342 #7
It's a bit of a kludge, but if the car radio head has an earplug jack, something like this adapter would do the job.
   / Better Radio For The LS MT342 #8
The stereo the dealer installed in mine was fine, the speakers that came with the tractor are of very low quality.
But the comfort of the rest of the cab is very nice:giggle:
   / Better Radio For The LS MT342 #9
That's the problem with using an automotive radio in a tractor.
I do stream audio from my phone to the headphones but I can't listen to local radio stations.
   / Better Radio For The LS MT342 #10
My Kubota radio has no audio output jack on the head. I'm playing around with an adapter like the one you mention, and tried tapping into the wiring harness but haven't had any luck so far.
I may have to replace the radio with one that has an earphone jack so I can use a streaming adapter. The problem then becomes how to protect it since it sticks out in front and can easily get broken off.
It would be nice if someone would make a radio for tractors that will stream audio.
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
JOHN DEERE 4100 TRACTOR (A51243)
JOHN DEERE 4100...
Nissan 5k Forklift (A51039)
Nissan 5k Forklift...
2014 MACK CXU (PINNACLE) (A50854)
2014 MACK CXU...
2001 INTERNATIONAL 4700 (INOPERABLE) (A50854)
2001 INTERNATIONAL...
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A51039)
John Deere 700...
