B9200 kubota problem pushing.
/ B9200 kubota problem pushing. #1
New old tractor guy
Kubota B9200
I’m new to the tractor world and just purchased a used B9200 kubota. Engine runs great, bucket works pretty well for a 20+ year tractor but the wheels lose power when I try to scoop a bucket of sand or dirt or anything really. Thought it may be fluid but they all look decent. It runs better after warming up but still the power to the wheels stops when pushing. The guy I bought it from told me it needed a high pressure pump or valve or something for other implements to operate. Any advice would be much appreciated. Thanks
/ B9200 kubota problem pushing. #2
What gear range are you using when trying to fill the bucket? You may be overpowering the hydrostat relief valve by not gearing "down".
I’ve tried all 3 gear speeds. If the throttle is all the way up it’s even worse. The middle gear and mid throttle seems to be the most effective combo
/ B9200 kubota problem pushing. #4
I would check your rear tire pressure. Some of the smaller tractor wheels don't get enough grip on the tire when the pressure is too low and they will spin but the tires won't and you can't see what's going on from the driver's seat
/ B9200 kubota problem pushing. #5
Have you ever ran a hydrostat?
They are backwards to conventional thinking. Meaning you have to let OFF the HST pedal for more power. IF its lugging/bogging down, and you are trying to give it MORE pedal thinking you are trying to give it MORE power, that is the opposite of what you need to do
Yes I’ve run hydrostat. This is the first piece of equipment I’ve owned but probably a couple hundred hours over the years. It’s not bogging down so much as the wheels just stop spinning. When I let off it allows me to push forward again. Sometimes I have to back up a hair and then I can go forward again. It feels like something is disengaging for a moment. It doesn’t rev higher or make any unusual noises though like a clutch would. The bucket runs fine during this too. The previous owner told me it needs a high pressure valve but it was for other implements. I’m starting to think that high pressure valve does more than he thought?
The tire pressure is good. The tractor wheels just stop moving
/ B9200 kubota problem pushing. #8
A video of the above would be helpful.
/ B9200 kubota problem pushing. #9
I wish I knew more about HST transmissions because it sure sounds to me like that is where the problem is. There is a high pressure pump in there, and it is a major component.
Lots of us old mechanics know standard gear transmissions quite well, but not much about HST even though they have become very popular. In spite of their complexity and requirement for nothing but the purest trans/hydraulic fluid, HSTs have been very reliable. Argueably more so than a clutch and manual setup.
But it sounds like yours either needs a replacement cable or needs an internal rebuild. Here is what happens normally: As you push down on the HST pedal you are allowing a "wobble plate" to tilt which in effect changes (raises) the gearing by allowing a high pressure pump to send more fluid to the drive motor. If that wobble plate moves - but the system doesn't have have the high pressure fluid available - then it is as though you shifted to a higher gear and let off on the power at the same time.
But it might not be the high pressure pump at all. It could just be the cable that moves the wobble plate. That cable goes from the HST pedal to where it wraps around a drum that turns a shaft that moves the wobble plate. I broke that cable on mine - which is how I know about it. A one hour fix. You can see the cable and see if it is doing its job by crawling under the tractor.
On most HST trannys there are ports on the transmission housing for measuring HST pressure. If it isn't the cable, then making pressure measurements is where I would start if it were mine, I would get a real good OEM shop manual for that model, make up some pressure guages (cheap to do) and make some HST pressure measurements. Of course a dealership mechanic might be able to do that too, but chances are they've never rebuilt a HST. Today they just replace them. And it may come to that as well.
Good luck,
rScotty
/ B9200 kubota problem pushing. #10
Good luck,
rScotty
My understanding from tearing into them in the past is that the wobble plate is part of the high pressure drive pump. The wobble plate is a disc that has a number of pistons riding round and round on one face. When that wobble plate is flat and perpendicular to those pistons, no fluid goes in and out of the pistons and so no fluid goes to your hydraulic drive motors. This is the neutral position where the tractor doesn't move. When you move your treadle or pedal, it angles that wobble plate. The angle makes those pistons riding around and around on the face effectively move in and out as they go around which pumps fluid in and out. The greater the angle the greater the amount of fluid that goes in and out and the faster your motors move. When you push your reverse treadle or pedal, the wobble plate angles back the opposite direction which reverses flow from your pistons. So it is effectively a variable high pressure pump that goes to your hydraulic drive motors internally in the hydrostat.
Here's a short YouTube video showing visually how it works:
Here's an example torque curve for one of those hydraulic motors. The graph reads torque on the y-axis and rotational speed on the x-axis. You can see that at high RPM the torque drops very low and that there is an optimum torque output somewhere around 2/3-3/4 of the max speed give or take. So this is why backing off a bit when you need more torque makes sense
There are two independent pumps on a tractor type hydrostat that are both driven by the engine input: the one described above for the drive motor then a second one with a fixed wobble plate angle that provides high pressure fluid to your three-point, steering, auxiliaries, etc.
So from a less theoretical and more practical standpoint, it is possible to have one pump go bad without the other; as it is possible to have a linkage problem. The linkages can be lever or cable type but they are complicated mechanical assemblies. I would start by taking off whatever covers you need to to visualize that linkage assembly and with the tractor off manually actuate your treadle or pedals and look closely at that assembly.
If that assembly is functioning like it's supposed to, then start checking pressures with an oem manual as suggested above
/ B9200 kubota problem pushing. #11
I have a B9200. Do you have significantly more push in 2nd and much more in 1st range than you do in 3rd range? Do you have beet juice in the tires. It can cause the tires to slip on the rims so the rim turns but the tires dont.
Thanks for all the input. It seems like more push in the 2nd gear but not much. Too much throttle and the wheels have virtually no pushing power so 2nd gear and mid to upper throttle is best.
/ B9200 kubota problem pushing. #13
Have someone watch rims and tires both sides. See if the beads are slipping.
/ B9200 kubota problem pushing. #14
Good points, but I have to disagree with one. That’s a torque-speed curve for an 20 Hp /1800 rpm electric AC (squirrel cage) induction motor. 4 pole motor (one revolution every 2 cycles), operating on a 60 hertz (3600 cycles/min) alternating current.
You wouldn’t back off rpms to get more torque out of a motor. The torque required is determined by the load encountered and the motor’s rpms will dip (self-regulate “automatically”) to the spot on the curve where enough torque is developed to match the load.
Looking at the curve closer, we can see that once an electric motor is running and rpms have gone over the “hump”, a motor will self-regulate its output torque to match the load requirements within a narrow rpm band (1400-1800). Note that the starting torque available at 0 rpm or 400rpm to get load up to speed is a lot less than maximum torque available when running near speed (above 1400 rpm).
Once running, if load exceeds max torque and rpms dip below 1400, rpms will dip to the left and go to 0 rpms in a locked rotor stall.
/ B9200 kubota problem pushing. #15
1st thing I would do would be to make sure the screen in the trans is clean and put a new oem filter on.
/ B9200 kubota problem pushing. #16
I stand corrected, thanks CobyRupert for clarifying
/ B9200 kubota problem pushing. #17
Yes. I should have mentioned that. Thank you. Since the loader responds well I assumed that the filters and fluid were good - but actually that is something that is always worth checking and especially with a tractor bought used.
I believe that model is one that has a cleanable wire mesh sump filter in the transmission that you have to lay beside the tractor to access - plus it has a fairly expensive spin-on filter. My experience is that when an older tractor has that combination then it is more than likely that both have been neglected.
So I'm with you, Leejohn. Best to clean the wire screen one and replace the spin on. Use OEM Kubota for the spin-on filter for several reasons..... but mostly because a hydraulic filter that expensive ($50) could be a medium pressure type that does feed the HST rather than being standard whole system suction filter.
For fluid, tractor people are all over the map on which is their favorite trans/hydraulic oil. My choice in a cold climate is John Deere HyGard Low Viscosity (Winter) . It's about middle of the pack price wise. Try not to fall off your stool when you see how much trans/hydraulic oil is. If kept clean & no water gets in it's good for a decade.
And final reason to do oil and filters is that if those don't fix it, then he could be in for some more involved work. Better to try all the easy alternatives first.
rScotty
/ B9200 kubota problem pushing. #18
"There are two independent pumps on a tractor type hydrostat that are both driven by the engine input: the one described above for the drive motor then a second one with a fixed wobble plate angle that provides high pressure fluid to your three-point, steering, auxiliaries, etc."
That is interesting... I have yet to own a CUT with hydrostat but have 2 lawn tractor mowers with hydros.
I wasn't aware some CUT's used a second fixed wobble plate hydro for 3 point , steering and auxiliaries.
Tractors I have owned all had separate gear, vane, or scotch (piston) style pumps for each of those functions
/ B9200 kubota problem pushing. #19
To visualize, here is an example scut hydro (Deere 1025): https://partscatalog.deere.com/jdrc/sidebyside/equipment/31878386/referrer/navigation/pgId/754793501
There are two piston type pumps one on top of the other. The variable drive piston pump is on top driven by shaft 13. Part 14 is your variable wobble plate on which rides piston assembly 32. The fixed angle pump is underneath driven by shaft 35 which also has a piston assembly 32. The fixed angle is machined into the housing 38 and rides on the thrust bearing assembly 34.
The op has a Kubota b9200 hydro:
Click on transmission then 'HST component parts" to see the parts diagram referenced.
Here you can see the analog assemblies on shafts 050 for the variable drive with wobble plate marked C and the piston assembly 020, then the fixed angle pump on shaft 060 and piston assembly 030.
There's usually an external charge pump as well mounted on the side of the hydro which may or may not also run the steering cylinder.
/ B9200 kubota problem pushing. #20
Any resolution?
2024 Better Built 7'x12' Trailer (A64127)
2024 Better Built...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63688)
2006 Cadillac GM...
Komatsu WA250 (A64126)
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
1000 GALLON POLY NURSE TANK (A64276)
1000 GALLON POLY...
