Anyone else seeing signs of an early winter?
   / Anyone else seeing signs of an early winter? #121
The earliest that I remember it here was about the 3rd week of October.
I remember having to use snowmobiles as the only way to get to deer camp in mid November. Definitely not this year, it was 70+ degrees 2 days ago now it's mid 30s and snowing however as others have noted signs of a long harsher winter, from previous yrs I've noted if the great lakes stay warmer later it usually means a lot more lake effect snow continuing later in the winter. I also believe it's the third yr in a row of lanina which also could mean a longer harsher winter in the great lakes region.
La Nina tends to cause warmer, rainier winters here. Perhaps I should buy a vacation home in the midwest someplace.
   / Anyone else seeing signs of an early winter? #123
El nino usually causes warmer shorter winters here.
   / Anyone else seeing signs of an early winter? #124
And I can remember hunting deer in Jericho, Vermont during Thanksgiving break and I HAD to wear snowshoes because the snow was waist deep. Forecast for this Thanksgiving is about 40°F.
   / Anyone else seeing signs of an early winter? #125
NOAA just issued a lake snow adversary for us.
   / Anyone else seeing signs of an early winter? #128
Snow on Thanksgiving isn't un-heard of, but certainly not common either. Even growing up in the 60s often as not bare ground, or an inch or two tops. How old were you when snow was waist deep?
   / Anyone else seeing signs of an early winter? #130
We are under the influence of a dying LaNina
The weather follows patterns so far since spring two weeks mild two weeks hot now two weeks cold two weeks mild. There will be a lot of variables this winter but by December cold will be extreme but only two weeks then mild for east mid west areas. Several polar vortexes will come negative NAO will be there as well. January a question mark right now.
The CPC is not something I put much faith in, look to weekly Euro,CMC,CFS, GEFS EXT and one will see what I’m talking about. In layman’s terms December will average colder and snowier overall
2014 Chevrolet Tahoe SUV (A56859)
2014 Chevrolet...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A58214)
2013 XLR...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
