Width of Snow Plow to Buy?
   / Width of Snow Plow to Buy? #31
Thanks for pointing out the maneuverability, where it's parked, etc. I have a lot of things to maneuver around, curves with trees to go around, and an 8' blade where I keep it would be inconvenient. 7' is sounding better and better. Besides, I am dangerous enough already with no implements wider than 6'
Glad I could help. I had learned by experience that some of the equipment I brought from our old place was just too big to be practical at our new properties. Sometimes smaller is better.
   / Width of Snow Plow to Buy? #32
Not sure what the area your looking at plowing or your snow falls but here are my thoughts. A 6' blade at a 30 degree angle will clear 62" so you might not run it at full angle, an 7' blade will clear 72". If your planning on leaving the blade on with the blower I would get the narrower blade as it will be easier to run with a rear blower. However if your just looking at cleaning up light snows then I would look at a 7' or larger. One method with lighter snows is to plow one way then reverse back with the blower getting rid of the snow berm you just made and finishing clearing the drive to full width if possible in two passes. If you have open areas such as parking pads I would consider an 8' as it will clear 83" at full angle or 8' if straight. However it will reduce the depth of snow you can move with it.
I ended up purchasing an 84" Braber snow plow from a sort of local tractor dealer that had one in stock. My tractor is having some work done so I won't be using it right away but it looks sturdy and well built. Welds looked good. Made in China for a Canadian company. I spoke with several dealers that sold the brand that said they have had very few warranty issues which were for more mechanical products rather than the plows. I got the manual since I don't have hydraulic hook ups on the front. The blower is set up to add the hydraulics later at a cost of $390.
Thanks for all your assistance! It made the process much easier.
   / Width of Snow Plow to Buy? #34
I have a kioti ck4010 with 8' front blade and keep a 7' box blade on rear for ballest and move snow. 8' width is nice but a little heavier than I would like at times.
   / Width of Snow Plow to Buy? #35
FYI to figure out the track width of an angled blade:
Cos(angle) x blade length
The angle should be in degrees, and make sure the calculator is set for degrees, not radians.
To use an example from this thread:
A 7 foot blade angled at 30˚
Cos(30˚)= 0.8660
0.8660 X 7 = 6.062 ft or just a shade under 73 inches
   / Width of Snow Plow to Buy? #36
I'd get 20' so I can cover both lanes of the highway in one pass.
Choosing a snow plow has been an interesting process. Having moved snow in several homes over the years with self contained snow blowers, a tractor pto blower, tractor buckets, rear blades, and shovels, and a little bit with an atv plow, I'm fairly aware that there are so many variables to what works the best. Also I am aware that the advice given by members here, which is much appreciated, is based on upon their particular conditions.
Conditions that include the amounts of snow, how light or heavy the snows are, how available are areas to move the snow to, the type and condition of the surfaces cleared, the width and shape of the driveways and open areas, the nature of the terrain, how available I am to deal with the snow before it deepens, settles and firms, how big and solid the berms from county plows, frequency of the snow, wind drifting, the tractor they work with, what other tools are needed where the tractor can't go, is the tractor open station or cab, and then there's the body.
Is it ok with driving backwards with a pto blower? How does it handle wrenching around a two wheel snow blower or a shovel? How does it deal with freezing temperatures and wind driven wet snow? Not just the wind driven falling snow but the snow hurled into the air by the blower?
Dealing with the snow is not just a job but something I don't always look forward to but also enjoy. It's a humbling way of meeting the forces of nature which are certainly sometimes dramatic. Like 5' of heavy snow interlaced with fallen branches, and towering berms at the road. Or coming home late at night from a trip with a few feet of heavy settled snow and a large berm at the road packed like concrete to get through just to get in.
   / Width of Snow Plow to Buy? #38
Very well said. (y)
Perhaps and an unknown adventure as well as a compromise.
2019 GALYEAN...
Adams 5 Ton HC Spreader (A55301)
Adams 5 Ton HC...
UNUSED WOLVERINE TDB-11-84W 84" BUCKET (A57193)
UNUSED WOLVERINE...
2011 JOHN DEERE 544K WHEEL LOADER (A52707)
2011 JOHN DEERE...
2005 Freightliner M2 106 Dumpster Carrier Truck (A55852)
2005 Freightliner...
200356 (A51406)
200356 (A51406)
