Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #21,231
If I were going to try that, I think I would first put some chain around it to prevent it from coming apart more.
Maybe a ratchet strap to draw it back together some.
Then, working alone, I would put some tension on it going the way I want it to go with my winch.
Start cutting below everything a little at a time (adjusting the winch as I go) until it breaks free.
Chain will slide up a tree a ratchet strap will blow a part with the force of a barber chair.
   / Tractors and wood! Show your pics #21,232
Yup... that could happen depending on where & how you chain it.
I was thinking of a heavier strap then you seem to be. They hold heavy equipment on semi's and I was just using it to close the split so it could be chained tighter.
Being aware of what COULD happen makes you think harder about what you actually do.
   / Tractors and wood! Show your pics #21,234
I understand that but, what’s the break out force of that strap? A barber chair will load that strap or chain instantly vs a load that’s constant. If something is very heavy at all such as with a lowboy application you will not see straps used it’s all chain and at least 1/2” or not 5/8” minimum even those don’t have the kind of strength needed to stop a barber chair.
   / Tractors and wood! Show your pics #21,235
Well you guys figure it out and come on over and show me how to do it.. I'll buy all the beer you can drink!
   / Tractors and wood! Show your pics #21,236
Hopefully you won't start serving until AFTER the tree is on the ground... or the evening before the tree is to come down. ;)🍻
   / Tractors and wood! Show your pics #21,237
Speaking of barber chairs. About 100ft tall. Mushrooms on the bark means it's dead and probably won't leaf out next year. Just wait for it to go over.
   / Tractors and wood! Show your pics #21,238
OK guys, this is what I started with,
And this is what I ended up with,
With the exception of two white pine logs on the load, the cherry tally is 324.3 bd ft...
All the pine that was with it in this second load,
has been milled and is gone too.
SR
   / Tractors and wood! Show your pics #21,239
In this case Hunt considering the surroundings, I'd leave it be.
None of us is gonna get there so you can have my beer.
Morooka MST 660VD Tracked Dump Truck (A52128)
Morooka MST 660VD...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
2014 Gillig 31+56 Low Floor Bus (A50323)
2014 Gillig 31+56...
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2021 Chevrolet...
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
20' One Trip Shipping Container (A50514)
20' One Trip...
