Width of Snow Plow to Buy?
   / Width of Snow Plow to Buy? #1
RidgeHiker
Gold Member
Upper California Mountains
Kioti DK5010 with KL5510 Loader & 72" Bucket. Kawasaki Mule Pro MX SE with 66" snow plow.
The widest point on my 50 hp Kioti tractor is about 63" at the rear tires. I am considering a 6' or 7' plow. The max angle the plow goes to is 30 degrees. What do you recommend and why? May order one tomorrow (Thursday 11/10).
Thanks for your assistance!!!
   / Width of Snow Plow to Buy? #2
I’d say 7 foot. I own a much smaller tractor, a JD 2025r. I don’t use a front blade but I do use a rear blade for snow removal and it’s 6 foot. It’s the perfect size for my tractor. This leads me to believe a 7 footer would be good for you.
   / Width of Snow Plow to Buy? #3
Seems with that width of tractor, you'd have to got with 7ft. :unsure:
   / Width of Snow Plow to Buy? #4
7 foot...once you angle the blade, you'll lose the width you will plow.
6 foot would probably result in a width less than the maximum width of your tractor
   / Width of Snow Plow to Buy? #5
Why a plow instead of a snow blower for your conditions???????
You can get really hung up and start ditch diving with a plow before you realize if the ground is soft.
The other thing is if you are going to mount it in the bucket you can really do some damage to your
loader frame.
I have a snowblower already. It has its uses but also want an attachment that is quicker to get the job done as well.
   / Width of Snow Plow to Buy? #7
Since we got a 6ft blade on our 6x6, we pretty much quite the blowing business. And we really do receive snow here.
   / Width of Snow Plow to Buy? #8
As Roy wrote.
I like least 8" be on rear tire angle plowing around corners.
   / Width of Snow Plow to Buy? #10
I agree with other's going with the 7' over the 6'. It is nice having some space between the tread and the berm of snow so you don't get sucked in. Will it be a rear blade or front plow?
UNUSED PABREAK DB220-84" HYD DOZER BLADE (A57193)
UNUSED PABREAK...
2023 John Deere 8RT 370 Track Tractor (A53485)
2023 John Deere...
(2) Nokian 400/80R24 Tires w/Rims (A56469)
(2) Nokian...
2010 Club Car Precedent Electric Golf Cart (A53424)
2010 Club Car...
2007 JLG SKYPOWER 800AJ TELESCOPIC MANLIFT (A52707)
2007 JLG SKYPOWER...
TURN PLOW (A57192)
TURN PLOW (A57192)
