2018 John Deere 5055E Ignition Switch Fuse blows
   / 2018 John Deere 5055E Ignition Switch Fuse blows #11
…Mine doesn't have the cold start advance sensor in the thermostat housing like the older models have.
Your 55 is a 3cyl. Completely different animal than the 4cyl with cold start sensor.
   / 2018 John Deere 5055E Ignition Switch Fuse blows #12
   / 2018 John Deere 5055E Ignition Switch Fuse blows #13
I am having the same problem with my 2021 JD 5065E. What ended up being the problem?
   / 2018 John Deere 5055E Ignition Switch Fuse blows #14
welcome to the forum isn't tractor still under warranty? Don't want to do anything to let JD out
   / 2018 John Deere 5055E Ignition Switch Fuse blows #15
Thanks for the help i have a 5055e same problem and it was that sensor unplug it and started right up
   / 2018 John Deere 5055E Ignition Switch Fuse blows #16
So exactly where is this sensor on the 3cyl engines ?
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
Okada Top 270 Hydraulic Breaker (A50860)
Okada Top 270...
2018 Ford Explorer AWD SUV (A48082)
2018 Ford Explorer...
2001 Chevrolet Monte Carlo SS Coupe (A48082)
2001 Chevrolet...
