   / Your last generator Maintenance Run #5,911
No, im buying retail. Its what propane is selling for up here.
you should fill your tanks at propane supplier, not Home Depot, tractor supply, and the likes. Their prices are way higher. Right now home dump is selling propane for $4.50/gal
Some Costcos sell propane by the pound. Meaning if you took a half-full tank in, you only pay for what gets added.
May not be as low $ as a dedicated propane supplier like grs is using d, but may give you a better option depending what is near you....
Rgds, D.
   / Your last generator Maintenance Run #5,913
Bulk propane around here is half the price of retail. $2 a gallon for several hundred gallons of home delivery vs $4+ for BBQ can refills or exchanges. The exchanges in particular only fill 20lbs cans with 15lbs. But they charge you for a full 20lbs.
   / Your last generator Maintenance Run #5,914
we've talked about a lot of generators here but I thought this one was pretty cool. I wish he had spoken about the inverter spec.
go almost all the way to the end at 33:50 and the "power house" is videoed for a few minutes.
if you live in the mountains this makes a lot of sense. Gravity is pretty consistent.
beautiful Fall weather here, generator is started occasionally and it always fires right up. Good feeling.
and yes he owns a tractor
   / Your last generator Maintenance Run #5,915
Had 60 mph gust all night long. Thousands without power. I only got 2 generator calls, both new customers. 1 was easy fix (bad control wire), the other…..big hole blown thru side of engine block. Fairly new generator. Sucks. Will be swapping out engine after i get a replacement. No calls from any customer….except a few asking if it was ok to run gen all day long,…. which i take as a very good sign.
   / Your last generator Maintenance Run #5,916
I make my own ethanol-free gas. I put 4 gals of gas in a 5-gallon water bottle add 2 qts of water and shake it like hell. Then I shake it some more. In a few hours the water has combined with the ethanol and is floating on top of the now-pure fuel. Carefully siphon off the fuel an that's it.
Nice build on the powerhouse. I'm a fan of hydro-electric (y). If we lose gravity, the planet is gone. If you are a fan of those type of installations, reading through back-issues of Homepower is time well-spent.
Propane stores nicely, but as you know, switches etc. can decide to hang-out with Murphy.....
Rgds, D.
Elevated wind yesterday, but no issues in the immediate area that I came across.
Given your extensive customer list, that's a healthy fleet, aside from that infant-mortality. It happens. Much backlog-time on replacement engines, or has that gotten better ?
Rgds, D.
Life in 2022..... for those that have no choice (drive 1 or 2 States away for Efree), that process may be useful for small-engine storage.
You've taken the "good" side of Phase-Separation, and put it to work. Also, even in road-vehicles that see regular use, BUT, are perpetually driven around with low tanks, illustrates what is in the tank for the fuel pump etc to chew on the time the tank gets run near-to fumes.... modern MPFI is pretty good, but can't run on that floating layer....
Rgds, D.
   / Your last generator Maintenance Run #5,920
GRS, what was cause? Oil? Did it blow under full load?
John Deere 6410 Tractor with Long Arm Mower (A54865)
John Deere 6410...
2012 TRANSCRAFT/WABASH 48X102 STEEL FLATBED (A55745)
2012...
Lockwood 480 Pecan Harvester (A55315)
Lockwood 480 Pecan...
Sundowner Rancher Express 20FT Livestock Trailer (A55314)
Sundowner Rancher...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
