Why are replacement parts so incredibly expensive?
   / Why are replacement parts so incredibly expensive? #41
Back in the 70's, there was an article that said if you bought all the parts to build a car, the total cost would be about 4 times the cost of the factory assembled car.
Bruce
Now it would likely be more like 40 times.
   / Why are replacement parts so incredibly expensive? #42
they got wind of the 5K rebates on EV's and immediately Tutuapp 9Apps Showbox raise the price by 5000. It's 'Biness'...
   / Why are replacement parts so incredibly expensive? #43
I bought a used Bush Hog 3008 this year to speed up my mowing. It was a well used unit with some hard use. I got what around here was a decent price. I figured I would have to put a little money into it to keep it going. So I have been looking at replacing some components and just can’t believe the price of stuff. Clutch Friction rings, it takes 4, are ~$40 a piece, springs, needs 8, for the clutch are ~$9 each. Stump jumpers are over $500 each, takes 2!
Does anyone buy that stuff? Or just start laying on the welds:)? I thought I would rebuild the rusted out clutch. Not anymore. I Will pull my shear pin pto off my snow blower if I can’t get the clutch serviceable. I guess. Seems like parts are a lot since a complete new 3308 is about $12k….
Cheaper overall to just buy a new or good condition used unit.
Well a new one is about $12k. I can’t afford a new one. I saw 1 good used one in my area for $10k. I can’t afford that either. I have never been afraid of fix or maintaining my equipment. But with parts beings so expensive, it seems I need to do without more than do with.
   / Why are replacement parts so incredibly expensive? #46
That must be a massive bat wing cutter? I was thinking about my $3200 6’ cutter.
HD 8’ rotary cutter. And everything here is more $$ than everywhere else…. But batwings are 15-20k.
   / Why are replacement parts so incredibly expensive? #48
Wow. My 6’ cutter was $3200 last year; LandPride. Probably not as HD as yours. But that’s a huge difference in price.
That is why I bought well used :). 6’ cutters are $4k now and anything over 7’ is 10k min.
   / Why are replacement parts so incredibly expensive? #50
A new “massive batwing cutter“ is now 30 grand. Probably because the price of fuel & steel at near record or record highs.
Adams 5T HC Spreader (A55301)
Adams 5T HC...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2005 PETERBILT 379 (A53843)
2005 PETERBILT 379...
2018 CUMMINS CM20-1 PORTABLE SKID GENERATOR (A55745)
2018 CUMMINS...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
