rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 13,193
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
55F and "Fair" @ 11:30, heading up to a high of around 66F for the day. Looks like winds are fairly calm. Good chance (60%) of rain coming in late tonight, probably around midnight or later.
Ten Day shows four day of high temps in the 70's in the forecast (but lots of clouds) ...
Will use one of those days to put the PHD on the Kubota and drill some holes for the trees and red bushes and get those in the ground. Still have some other stuff that needs planted as well.
Also need to replace the bearings on one wheel of the dump cart.
Woodpeckers tapping on the siding, probably should check hopper feeder. Need to move nyjer feeder pole and feeders from around back and refill those.
Main agenda item for today will be to finish up gutter covers on backside of pole barn.
Hope to get The Woman start coating the edges of the 2 x 8 x 14's with BLO.
May dispatch Her down to Menards at some point to pick up the order for the door jamb and trim. Probably before She really gets started on anything here.
She got gas for the Cub while She was out yesterday so I'll need to unload that from the car and get it put in the Cub. It will likely be the last ethanol blend gas that goes in the Cub this year. Once I have it run out, I'll put some E0 in for the winter.
Beyond that maybe cut some more foam board panels for the interior perimeter of the barn.
Have some grading work to do outside to eliminate a spot that has standing water.
Plus whatever else comes up.
Hope everyone has an enjoyable, productive, and safe Sunday ...
