Building a house with 3" EXTERIOR insulation AND 2x6 walls!
   / Building a house with 3" EXTERIOR insulation AND 2x6 walls! #1
Drewintoledo
Ohio
LS MT225HE
Triple pane windows. Southern facing house with higher solar heat gain coefficent glazing. Hope to heat with a candle!
Will have fresh air exchange system.
If you like this kind of thing follow along if you wish.. check out the last few videos of mine if ya'll like it!
   / Building a house with 3" EXTERIOR insulation AND 2x6 walls! #3
I helped a friend do that in the mid 70's. I later asked him if the 6 inch walls were worth the extra expense. He said no, but he lives in the panhandle of Florida. Good luck with yours!
David from jax
David from jax
Ahh yes, makes sense. I could see that in Florida where the goal is to keep it cool. I am up in the 41st parallel where if it gets too cold ya freeze your knickers off. The way I see it is that when you put a coat on, you don't stick the coat between your ribs, you wrap it around them. Just like the studs in a wall I am wrapping around the studs (and between). This should reduce the thermal conductance through the studs and hence into the house considerably.
   / Building a house with 3" EXTERIOR insulation AND 2x6 walls! #5
Years ago in Mother Earth News they showcased a double envelope house. Like a house with an overcoat. Lots of solar gain, air space for less thermal loss, and featured greenhouse space for self sufficiency.
   / Building a house with 3" EXTERIOR insulation AND 2x6 walls! #6
I live in the south, but I built our 900 sq ft cabin with 2x6 studs and spray foam, and 3/4" foil backed foam insulation on that, then a 3/8" air gap which also serves as a rain screen, then hardie plank siding on top of that. The HVAC guys wanted to put a 24,000 btu unit in (without doing any calculations). I don't have access to the software to do a proper manual J calculation, but what I did come up with was around 12,000. I chickened out and put in 18,000. now after having it for a few years, my 12,000 was correct. We use very little energy there. One of my reasonings was that even though it cost a little more now, energy costs are only going to go up, and it'll be much more expensive to do it later.
   / Building a house with 3" EXTERIOR insulation AND 2x6 walls! #7
I really like fresh air movement through any space I live in.
Smells and the feeling of "closeness" are nothing I care to entertain.
I keep the window over my bed cracked open year round.
Winters in Vermont can get cold.. ;-)
   / Building a house with 3" EXTERIOR insulation AND 2x6 walls! #8
Fun build. I always enjoy seeing what people are doing around the country.
From what I've learned, sealing air from getting through the walls is more important then R value. Foam works great for this, but so does the newer polymer coatings, or ZIP System and Tape. Once you seal the walls, then R-Value matters the most in the ceiling where heat and cold travel through a house.
Something else that I find really interesting is that a lot of people up North rely on snow on their roof to create a thermal layer to keep the heat inside the house. This might be why the focus on the walls so much.
I haven't ready anywhere that you can increase energy efficiency by adding R-Value to a wall over R20 if you have the walls air tight. Wind is the biggest challenge in sealing the walls. Especially around windows and doors.
   / Building a house with 3" EXTERIOR insulation AND 2x6 walls! #9
Does that porch overhang only have 1 2x4 holding it up? Scary!
Cool looking house, love the concept.
   / Building a house with 3" EXTERIOR insulation AND 2x6 walls! #10
Thanks for sharing!
Maxi Grapple (A50775)
We Don't Dial 911 Decorative Sign (A55758)
We Don't Dial 911...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A55788)
2012 Mack CXU613...
Chains and Binders (A53316)
Chains and Binders...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
