2.5 yd Pull-Type Scraper -- Pulled with 50HP Tractor
   / 2.5 yd Pull-Type Scraper -- Pulled with 50HP Tractor #11
Watched your "loading" video. Put your FEL on and fill the bucket. You'll get along a lot better. You obviously have more HP than needed and less traction than needed.
Came out to just over 2 yards counting the sideboard extensions so I am probably loading about 1.75 on the average trip.
   / 2.5 yd Pull-Type Scraper -- Pulled with 50HP Tractor #13
Looks like fun.
Is that 90 degree elbow above the front wheels a proper hydraulic fitting? (Looks like a cast pipe fitting)
As far as I know everything is factory, I will look at it tomorrow. I think it is a curved hose but the angle of the picture makes it look like a 90, if I am look I'm not at the same thing as you.
I know this thread is rather dated, but here is a new video I just made that's higher quality than the previous ones:
I need to pull it in the shop and build new sideboard extensions for it...
   / 2.5 yd Pull-Type Scraper -- Pulled with 50HP Tractor #16
Someone else was singing the praises of those scoops several years ago and I've wanted one ever since.
   / 2.5 yd Pull-Type Scraper -- Pulled with 50HP Tractor #17
Good video - shows exactly how good it works. I've never seen one. Now I know. (y)
gg
Digging up an old thread to add some old video I just found and uploaded. Hopefully this helps anyone that is thinking about getting something like this.
   / 2.5 yd Pull-Type Scraper -- Pulled with 50HP Tractor #19
The soil you're moving looks like it had been previously been dug up and dumped there. Is that the case?
   / 2.5 yd Pull-Type Scraper -- Pulled with 50HP Tractor #20
I have the DuraBuilt brand scraper. Mine does not have front wheels like yours. I wish I did have the front wheels. Mine is lifted and lowered with the 3 point hitch. Their website says mine is the 3 yard model.
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
202481 (A54757)
202481 (A54757)
2011 Ford E-350 Passenger Van (A53422)
2011 Ford E-350...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2019 WACKER NEUSON LIGHT TOWER (INOPERABLE) (A55745)
2019 WACKER NEUSON...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
