1.5 inch flexible aluminum conduit
   / 1.5 inch flexible aluminum conduit
Thanks for all the good inputs.
   / 1.5 inch flexible aluminum conduit #12
AS others have said, thats too big for really anything in the shop.
I wired my whole shop with 3/4" EMT for the welders and air compressor plugs, and anywhere I was pulling several circuits. And 1/2" for 1-2 circuits.
Cant even hook 1-1/2" to a workbox.
And at $1.40 for the flex.....it will cost you more and look like crap. 1/2" EMT is like $0.70/ft and 3/4" is a little over a buck a foot.
On a related note is cerrowire, 12-2 with a ground pretty much a direct replacement for 12-2 romex?
   / 1.5 inch flexible aluminum conduit #14
If its labeled NM-B then yes....that is the typical "romex". Romex is a brand but has gotten the generic term for indoor wiring....similar to crescent wrench/adjustable wrench, or channel locks / slip-joint pliers, or kleenex/tissue.
Similar to NM-B/romex is is UF wire. Which looks like "romex" but usually grey. Its rated for outdoors. UF-B can also be used indoors, and is usually cheaper than NM-B, but not as easy to work with and strip to attach outlets and switches
   / 1.5 inch flexible aluminum conduit #15
I just redid my barn wiring to prevent rodent damage. I started with aluminum flex, but the fittings were expensive and the job didn't look good. Difficult to pull wires through. Ended up doing most of the job using a lot of 3/4" EMT and the rest of the 1/2" that I had laying around from another project.
If I was doing the job again - and on all future wiring jobs - I will standardize on 3/4" EMT tubing and wire with 12-2 NM-B with ground. That combo will do anything, is large enough for multiple circuits, and is small enough to be workable & reasonably priced. And is available everywhere. Plus it looks good.
rScotty
   / 1.5 inch flexible aluminum conduit #17
12-2 with ground is just a description of wires you need. It could be any type of covering or protection. MC cable is way different than NM.
AND ROMEX IS SIMPLY A TERM, not a legal wire description. If you ask for romex, you get NMB.
   / 1.5 inch flexible aluminum conduit #18
My entire shop is run in EMT, and i wired my house in steel flex. Comes from years as commercial electrician, and the fact that i hade a 28’ trailer full of the stuff.
   / 1.5 inch flexible aluminum conduit #19
My shop was done in 3/4 EMT and 12/2 for most circuits (less W/D, water heater, mini split, welder and RV).
I’ve added some additional circuits using the combination of 3/4 EMT and flexible armored wire- wish my bends looked anywhere near as good as the pro who did my original installs.
   / 1.5 inch flexible aluminum conduit #20
EMT is definitely the way to go in a barn, esp. if it's exposed and visible. But you'd do well to not bother with pulling NM-B thru EMT, rather just pull individual conductors (eg. THHN). Romex (i.e. NM-B) is a ***** to pull thru conduit, and there's absolutely no need for it.
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A55853)
2014 Glasstream...
1993 CATERPILLAR 416B BACKHOE (A52707)
1993 CATERPILLAR...
1998 BOMAG BW172D-2 SMOOTH DRUM ROLLER (A52707)
1998 BOMAG...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2017 Ford Escape SUV (A55853)
2017 Ford Escape...
1977 Ford F-100 Ext. Cab Pickup Truck (A53422)
1977 Ford F-100...
