So you think you are hard on equipment?
   / So you think you are hard on equipment? #11
It worked for my computer as posted.
Yikes! Guess this is one of those situations rubber treads just wouldn't cut it...
I’m glad the link worked for you
The glowing tracks were impressive
   / So you think you are hard on equipment? #13
Same video but posted on Youtube
   / So you think you are hard on equipment? #14
No way! Not for me. How would you get out if it broke down in there?
Actually how would you get out of the glowing machine at all?
   / So you think you are hard on equipment? #15
Welcome to hell. Your shift starts at 6:00am.
   / So you think you are hard on equipment? #16
I am guessing there is no grease in the joints. I would want to use diesel that wouldn't burn. They must have a GREAT AC unit in the cab. Talk about the "Hot Seat".
   / So you think you are hard on equipment? #17
The one i saw was remote controlled, no operator in it.
   / So you think you are hard on equipment? #18
Looks like Cat builds a purpose build track loader for slag work.
Includes high temp seals for the undercarriage.
   / So you think you are hard on equipment? #19
STEEL MILL OPERATING RECOMMENDATIONS
Steel Mill Operating Recommendations​
Caterpillar recommends that Steel Mill machines be exposed to hot slag for less than 15 minutes each hour to allow for adequate cooling time between cycles. Typically, two machines per furnace and a backup machine for the site provide the best uptime. The timing, frequency and duration of the work and cooling cycles varies by job site, but exceeding the recommended exposure time will prevent the machine from meeting expected performance levels.
   / So you think you are hard on equipment? #20
I must have missed this episode of Dirty Jobs. :)
Enclosed Service Truck (A55788)
Enclosed Service...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
12-Ton Hydraulic Bottle Jack (A55852)
12-Ton Hydraulic...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
40006 (A53422)
40006 (A53422)
gravely riding mower (A55758)
gravely riding...
