Springs for Gannon H120 Box Blade
   / Springs for Gannon H120 Box Blade #1
Tntcwg3
Member
Highlands, Texas
Bad Boy 4035H (Branson 3515H)
Looking for a source or ideas for replacement springs for a Gannon H120 Box Blade. There are two springs on each side, one which operates in a radial manner on a rod, housed in a tubular housing with a second traditional pull spring attached to the extended arm of the first spring. I haven't had any luck searching online, hoping someone here might have run into this issue before.
   / Springs for Gannon H120 Box Blade #2
Have you already tried Woods since they own Gannon now?
Not yet, I did find an old thread on here that did fortunately have the part numbers that I need! It should make the search that much easier!
   / Springs for Gannon H120 Box Blade #4
Good deal.
Someday want to put my Gannon back to fully Operational hydraulic rippers.
   / Springs for Gannon H120 Box Blade #5
Thats a hefty spring. Usually smaller ones i can come up with more possible replacements. One that size, only thing that comes to mind aside from the actual correct replacement part, is maybe some trip springs from a small snowplow. Or.. tensioner springs from large belt drive mower decks. Or maybe ‘porch spring’ / ‘screen door spring’ / ‘storm door spring’? Not sure best term for that one.
Let us know how it goes getting the correct parts!
   / Springs for Gannon H120 Box Blade #6
Woods did aquire Gannon, but has since dropped the line.
There is a dealer in California that may have the springs, but not sure what happened to the Gannon line.
Alternately, both Gearmore in California has copied a lot of the Gannon scrapers and may have springs.
   / Springs for Gannon H120 Box Blade #7
Thanks Tractor Tech, I did not know that.
Wow
I know they have always been upper tier weight, strength, and price.
Kind of surprised that Woods would drop them.
   / Springs for Gannon H120 Box Blade #8
These guys have a lot of different springs in stock and I've actually had them make custom springs for projects before
   / Springs for Gannon H120 Box Blade #9
Wow
I didn't know it either and not sure why, but if you look at Woods site, the only thing left is a downloadable manual for hydraulic scrapers. No Gannon parts come up. There has been a lot of realignment in the Woods company if you poke around on their site.
The Demo PowerSports has all the parts books online, but not sure what the deal is with parts. These guys are located not far from where Gannon was produced in California. I am going to call them Monday to see if they can shed some light on Gannon, but Deere bought the plant in Thibodaux. LA that makes box scraper knockoffs for them and companies like Gearmore in California have made a copy for years now.
   / Springs for Gannon H120 Box Blade #10
There's a company called Demo Powersports that stocks them under "Woods H-120 Manual Landscaper"
Part numbers H056A, H056B, H013, E013
UNUSED WOLVERINE PFA-113300G 48" PALLET FORKS (A57193)
UNUSED WOLVERINE...
UNUSED FUTURE 24" CAT 305 EXCAVATOR BUCKET (A57193)
UNUSED FUTURE 24"...
Loader Forks (A56469)
2004 BMW 545i Sedan (A55853)
2004 BMW 545i...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A56858)
2018 Nissan Titan...
