Overheating M9540
/ Overheating M9540 #1
Rambo33
Member
Australia
Massey Ferguson
Hi,
A friend recently bought a M9540 with a front 3 point linkage to run a mulcher. He's new to tractors and he was complaining about it overheating, then he proceeded to tell me it is running at 2600rpm. I have very little experience with kubotas, is this normal? It seems very high and can't be good in the long run.
/ Overheating M9540 #2
According to Tractordata.com Kubota M9540 engine is rated at 2600 rpm. Are radiator fins free of debris? It's possible thermostat is stuck. What condition is fan belt & is it snug. When engine is cool remove radiator cap, start engine & look inside radiator neck for tiny bubbles. Bubbles indicate engine compression is getting into cooling system.
/ Overheating M9540 #3
Sounds to me like it could be a number of issues but most likely a plugged with crud radiator. Tell him to get a Radiator Genie and clean it out and clean it often, along with all the other heat exchangers out front like the charge air cooler, the AC condenser (of it has one) and the transmission oil cooler. as well. I clean mine daily when farming, every evening.
In fact I carry a small HF Bauer 20 volt blower behind the seat to blow out the rad and components in the field if chaff gets to be an issue. Only takes a few seconds to clear them.
Any implement like a mulcher out front will produce a lot of chaff and fines that get sucked right into the radiator immediately. Overheating the engine consistently will eventually cause severe mechanical issues.
/ Overheating M9540 #4
As always start with the simple stuff, eliminate it as a possible issue then progress. Tx Jim has great suggestions. You can also check coolant temps on the supply and return side to see if the rad is doing its job.
/ Overheating M9540 #5
Overheating seems to be a frequent complaint with Kubotas. My experience is all with the smaller ones however. These principles apply regardless of size:
1) Unlikely to have anything to do with rpm
2) Both posts 2 and 3 offer good comments on it ...first make sure the radiator screen and fins are clear and clean. That is byfar the most common cause of overheating. My 81hp MF has never ever overheated except when seeds and weeds obscured the radiator and prevented air flow.
3) While diesels are a little less sensitive to coolant pressure (maybe?) you need to make sure the radiator cap is holding pressure. Coolant boils at a much lower pressure for a given temperature. If you replace the thermostat or prove that the thermostat is letting coolant to the radiator then check the cap because water boils at a higher temp proportional to pressure. That's what the radiator cap is for.
Note: My local tractor repair shop has simple quick and easy tools for pressurizing the radiator, finding leaks if any and detecting bubbles coming from combustion.
4) If you have bubbles coming from combustion you probably have a blown head gasket or even worse a cracked head if you ran it super hot for a long time.
5) When the engine heats up you should get some overflow of coolant to the plastic jug. That should be sucked back into the radiator when the engine cools. After it cools check the radiator level. If it is full you probably do not have these other diseases.
6) I have always questioned the adequacy of the water pumps on Kubotas. They OUGHT TO BE overkill and provide way more flow than required. I'm not so sure they do. I cannot say this applies to the large Kubotas (??)
Please let us know what you find.
/ Overheating M9540
Thanks everyone. I'll pass on the advice. I know he's very diligent with his skid steers so I'd be surprised if he's been lazy with this. I've used fords, fiats, deeres, deutzs, but never a kubota hence why the 2600rpm working rpm was surprising.
/ Overheating M9540 #8
Thoroughly clean the radiator with garden hose sprayer set on the stream spray mode, then re-assess.
Won’t cost anything but 1/2 hour of time and that’s always been the culprit for overheating on mine.
/ Overheating M9540
Out of curiosity, Do all kubotas run high rpms like that? I have a 100hp tractor that is making 100hp at 2200 rpm and 375nm of torque at 1600 rpm. The 9540 i read is making about 320nm at 1500rpm. I went onto another manufactures site and read up on one of their 90hp tractors, 90hp at 2300rpm and 351nm of torque at 1500rpm.
/ Overheating M9540 #12
With any front mount PTO implements kicking up dust, you are bound to get the radiators dirty, which will raise temps.
/ Overheating M9540 #13
Best investment I ever made was a cordless blower, in my case a Bauer 20 volt blower with a concentrator (tapered snout) on the business end. I carry it behind the seat and blow out the rad from the fan side out when I'm out shredding or running hay, the chaff always finds it's way into the radiator.
Not expensive either. Tool only is about 35 bucks.
/ Overheating M9540 #14
Lots of stuff finding it's way into the radiator... Do keep in mind that Kubota's have always had an issue with repeated overheating causing blown head gaskets.
The cab was a warning that the unit was going into a hot and dusty work environment.
/ Overheating M9540 #15
if the radiator is picking up that much debris, blow out the air filter as often as the radiator. (from inside out)
have that same engine (chipped 10hp less than yours) & the temp has remained normal throughout the course of it's life. i would never allow the temp gauge to raise over 1 notch normal.
in those severe conditions, would suggest more frequent engine oil changes as well, lots of abrasives in the air
best regards
/ Overheating M9540 #16
For reference, when I mow in tall grass I have to clean off the hood screens and radiator screen about every 30 minutes, they get packed full that quick with grass and ragweed seeds.
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
2016 Nissan Sentra Passenger Car, VIN # 3N1AB7AP6GY307338 (A61165)
2016 Nissan Sentra...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2022 CORMIDI C85 STAND-ON MINI DUMPER (A62129)
2022 CORMIDI C85...
2012 DOOSAN G25KW GENERATOR (A60736)
2012 DOOSAN G25KW...
