Bathroom tiling - regrouting - need Dremel tool with Cubitron for removing grout
   / Bathroom tiling - regrouting - need Dremel tool with Cubitron for removing grout #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
For some odd reason my wallet has never wanted to release the funds to pay someone else to redo a bathroom, especially things like putting up small tiling projects. And I've generally gotten good reviews of the results.
But due to the pandemic my wife and I were gone from the house in Virginia for nearly 2 years and my son who was there apparently never remembered to clean the tile in the shower he used everyday.
We had in the past 30 some years just sprayed and wiped it down with no problem. However he let black mold start to live there and many of the grout lines which had been bright white turned black.
I've got most of it cleaned up with a combination of an oscillating/multitool and a manual tool but I really could use a bit for my dremel to "polish off". The other 2 tools often leave a stain of grout on the tile edges. I've been cleaning that off with 3M Cubitron and lots of elbow grease. I'm thinking a dremel with a conical bit of similar material would make it real easy,
Anybody know of such a bit?
/edit- sort of like a dentists buffing drill
   / Bathroom tiling - regrouting - need Dremel tool with Cubitron for removing grout #2
scrape it off with a razor blade. Using a buffing wheel sometime might damage the glazing on the tile.
This is on the curved part of the tile. Razor blade takes too many scratches. Manually buffing with the Cubitron just takes excess elbow grease.
   / Bathroom tiling - regrouting - need Dremel tool with Cubitron for removing grout #7
Cubitron.... Isn't that the planet the Transformers come from? šŸ˜†
   / Bathroom tiling - regrouting - need Dremel tool with Cubitron for removing grout #9
I’m wondering if a gel bleach would remove the mold without regrouting?
   / Bathroom tiling - regrouting - need Dremel tool with Cubitron for removing grout #10
2008 Chevrolet Uplander LS Van (A55853)
2008 Chevrolet...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
White Metal Roof Panels (A55758)
White Metal Roof...
2016 Chevrolet Sonic LS Hatchback (A53424)
2016 Chevrolet...
PULL TYPE CONCESSION STAND (A54757)
PULL TYPE...
2005 FORD F-150 XL (A55745)
2005 FORD F-150 XL...
