Things you could order over 50 years ago that you can't order now !
Status
Not open for further replies.
/ Things you could order over 50 years ago that you can't order now ! #541
Are you in Oregon? There are 177 charging stations in the Eugene area. Eugene, Oregon EV Charging Stations | PlugShare
And where are they at......., not gas stations. I know where the others are. They are in lots of places. I live here. There are no charging stations at the local "gas stations." We got one Chevron, that is out side the Eu/SP area. The rest, in city, are almost arbitrarily set up here and there. I know were they are, but if I was driving I5, how would I know. I'd have to depend on an app, on my phone or something that gave me accurate information. And that information doesn't say that the charger is in a parking garage, that you have to pay for, just to go in. Or if if that charging station was compatible with your particular EV car as to fast charging. If this is to work, then we need to have signage that here is an EV open charge station. I don't see that visually, along any major hiway we have here on the West Coast. Bad old gasoline, oh,..... I can find that with out any app. And its the same thing, same cost, if your vehicle gets near 40 MPG.
/ Things you could order over 50 years ago that you can't order now ! #542
Why does it matter where they are located? If I can find out from the other side of the continent, then I'm sure they will be apparent to the people who need them. When I was traveling before the internet there were time when gas stations were hard to find; yet I never ran out of gas. I planned my trip using maps and noted where the towns were.
This site PlugShare - EV Charging Station Map - Find a place to charge seems to give the exact information you are looking for. Anybody who buys an EV should know to plan ahead; just as they had to plan ahead for gas stations 120 years ago.
/ Things you could order over 50 years ago that you can't order now ! #543
Back when abortion was illegal, college girls inserted a catheter through the cervix and filled the uterus with pHisohex. It was an effective technique that did not risk bleeding. They didn't know about toxicity of hexachlorophene. I'm sure they can find a safer substitute now that dorm room abortions are coming back into style.
Most probably don't know but California just positioned itself to be the abortion capital of the United States so no need for dorm room abortions...
In California Abortions to be at no cost with no residency requirement, providers shielded from professional liability, health records effectively sealed, MD not required in first trimester as Nurse with training can perform, etc...
Ten new laws just went into affect...
The lines are being drawn quicky...
/ Things you could order over 50 years ago that you can't order now ! #544
I doubt some kid scraping by in college is going to be able to afford a plane ticket to the Golden State and back. Abortions are not rocket science. Women did them all the time right there in River City. The politicians can rant and rave, but they aren't going to turn back the tide.
/ Things you could order over 50 years ago that you can't order now ! #545
All they are going to do is cause more women to suffer permanent damage or die... just like in "The good old days." I've far from a proponent, but focusing on preventing unwanted pregnancies in the first place is the way to reduce abortions. Find some rapper who will write a song, making it fashionable to wrap it up.
/ Things you could order over 50 years ago that you can't order now ! #546
Local hamburger joint has one of their 1960 price signs mounted on the wall. Hamburger -0.55 Cheeseburger - 0.65 fries - 0.15.
/ Things you could order over 50 years ago that you can't order now ! #547
Even the 70’s a burger and shake less than a buck every Saturday on my lunch break…
/ Things you could order over 50 years ago that you can't order now ! #548
Yep. And now the antiabortionists are prohibiting CONTRACEPTIVES!! I swear their only goal is to turn women into law breakers.
/ Things you could order over 50 years ago that you can't order now ! #549
They certainly aren't concerned with the health and well being of people who disagree with them.
/ Things you could order over 50 years ago that you can't order now ! #550
The false front wagons were home made. Not sure if the 90deg unloading forks are still available.
The ratchet jack here is in the toolshed yet, and the forks are still hung on the rafters ready to be used.
/ Things you could order over 50 years ago that you can't order now ! #551
w
What were those used for?
/ Things you could order over 50 years ago that you can't order now ! #552
We had silage wagons that would unload from the rear, into the dog leg on the silo blower. The wagons had a movable front section, attached by cable to a rotating pipe column in the back. To unload we would unhook the back door to the wagon and prop it up, attach the ratchet to the column, the column turns and would pull the silage back, claw the silage off with the 90deg tine fork onto the blower. This would be 1959. Just before that, they had used the corn binder and ensiler at the silo, so this was a big improvement in productivity. Some silo blowers even came with a ratchet jack as part of their transmission assembly.
Even further back they used the binder, ensiler, and an elevator. The picture of the JD B with brick silo is ours in 1959. And just for fun, the same silo in 1908 with an elevator, ensiler and early gas engine.
/ Things you could order over 50 years ago that you can't order now ! #553
@BnRidge ⚡💡 now I get it! Thanks for sharing. I couldn't figure what the ratchet jack was.
Those ensilers scared the heck out of me as a kid. They just seemed to me to be designed to eat people. I wasn't too wild about the big drive belts, either...
All the best,
Peter
/ Things you could order over 50 years ago that you can't order now ! #554
you're no better than the biased media...using the term "antiabortionists" when what you mean is a minor yet loud portion of the general conservative populous that don't think abortions should be used as birth control etc...
/ Things you could order over 50 years ago that you can't order now ! #555
The anti birth control crowd is mostly Catholic, since the Pope says birth control is evil. The only people paying attention to that are trolling for votes. As you say, the freakazoids are loud. Nuts, though. Little Susie can mail order her morning after pills in a plain brown wrapper and nobody the wiser.
Actually, Louisiana SB 388 passed and signed by the governor prohibits receiving those medications from out of state.
Status
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A61307)
PENDING SELLER...
2018 Chevrolet Camaro 1LT Coupe (A59231)
2018 Chevrolet...
2020 DRAGON ESP...
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
2021 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
