Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #20,971
Good to see that your wagon is hanging in there - It's close to being a classic.
gg
   / Tractors and wood! Show your pics #20,972
How much fire wood do you think you could cut in
a day with a machine like this??????
willy
   / Tractors and wood! Show your pics #20,974
Not much more than do now. Still limited to how many trees I can cut and drag out of the woods. :rolleyes:
   / Tractors and wood! Show your pics #20,975
willy
I'm going to say not much, as this is a lot of photoshop editing, the mismatched alignment and the repetitive logs on the ground are dead giveaways. Now if the machine did actually exist and would do 3 logs at once, you would need quite the staff running a lot of machines to keep this beast fed!
   / Tractors and wood! Show your pics #20,976
No matter, the splits are too small for me anyway, I want to make a fire that will last. SR
   / Tractors and wood! Show your pics #20,977
Here is the clip it shows the actual machine and
a new way to cut down a tree??????????
To me the notch is way too small to start with
and I never had to use a wedge to cut down a tree
Personally I would cut or split our fire wood just
small enough so it would fit the opening of the
door of the wood stove. Also if its a round piece
that would fit threw the stove door I would not
split it. Small pieces of fire wood are good for a
wood cook stove
willy
   / Tractors and wood! Show your pics #20,978
wood cook stove
willy
Some pretty cool machines thats for sure! Now I've never dropped a tree with a bottle jack although I've seen quite a few videos on it... But I almost always use wedges when I drop one.
   / Tractors and wood! Show your pics #20,980
Agree. My ideal size is 9" diameter. Still easy to toss in but does not burn right up. I settled on 9" because it is the distance between the tip of my big finger and the tip of my thumb when stretched out. I don't have to guess or eyeball the size when splitting, built in measuring tool. And guess what, I cut 18" lengths. Two spans of my hand, again, no measuring tool. Makes for a very even woodpile.
2016 Ford Fusion Hybrid Sedan (A50324)
2016 Ford Fusion...
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
UNUSED FUTURE SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE SKID...
377811 (A48836)
377811 (A48836)
90018 (A48082)
90018 (A48082)
UNUSED FUTURE MINI SKID STEER HYD BREAKER (A51244)
UNUSED FUTURE MINI...
