Searching for new or used front rims
/ Searching for new or used front rims #1
Chrthomas
MT372
I am in need of replacement front rims for a MT372. They are 3 lug spilt rims. Has anyone ever found a suitable replacement (used are impossible to find)?
/ Searching for new or used front rims #2
A shop that builds rims can take the centers from your existing rims and weld them into just about any rim width you want. It's not cheap but can be done. You may be able to score used rims as well. Contact Valley Power
/ Searching for new or used front rims #3
Your MT372 is 2WD then. The 4WD has 5-bolt pattern.
As a 2WD machine, Front: 4.00-8. It's very common for lawn tractors and small trailers. You should be able to score rims in that size all day long in both 3 and 4 lug patterns. The center hub area is the only standing issue, yet a good machine shop can make a simple correction for you.
Could you provide the center hub hole size and then the lug to lug spacing and the lug diameter for the lug pattern. We could find even better rims for your machine will little trouble.
/ Searching for new or used front rims #4
Oh, if I recall right, the MT372 was once a SATOH model, just rebadged. So there are options out there.
/ Searching for new or used front rims #5
Anybody with a welding machine could solve this problem. I've done it myself.
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
